Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-18-2009, 10:48 PM
Fuelhog 5212 Fuelhog 5212 is offline
Fuelhog 5212 is starting off with a positive reputation.
Kerosene
Howdy, I was directed here with this query. Has anyone used Jet fuel, Jet A to be precise in an IDI 7.3 ? Jet A is basically kerosene and I heard you should either mix it with diesel or add motor oil (I am not sure what type) if it is used 100% - other than that I'm just looking for input. I can get the stuff pretty well free but don't want to cook some component.
  #2 (permalink)
Old 08-18-2009, 11:17 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
It will run, but it has zero lubrication, you need a lubricative additive. If the fuel is free, you are saving enough to afford to use a good additive, I would double the dose each time. Where do you get this free, just out of curiosity, some kind of dumped fuel? If so, I would make sure to filter it good.
__________________
1997 F250 Crew Cab 4x4----
1997 Dodge 2500 4x4 Cummins Automatic
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #3 (permalink)
Old 08-18-2009, 11:28 PM
Thanks, not sure where I will get a lubricant additive (I live in a hic town and if you go into a shop and ask for something like that they look at you like you have a second head) but was hoping that the diesel 50/50 mix would be adequate - I was thinking maybe a mineral type of oil would be ok if I needed to add anything. The fuel I am getting is clean, probably more so than the stuff you can buy at the pumps.
  #4 (permalink)
Old 08-19-2009, 09:46 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
Kerosene has a lot higher flash point than dinodiesel. I would not go above 20% Kero/80% diesel, and you should add some Bio or DK to the mix for lubrication.
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #5 (permalink)
Old 08-19-2009, 11:34 PM
Thanks for that, 80/20 sounds reasonable, I was not thinking of the higher flash point - I will give it a try and let folks know how it works.
  #6 (permalink)
Old 08-21-2009, 02:21 PM
Just another dumb question, would anyone know if you could use say a 100:1 mix of 2 cycle oil with the kerosene for extra lub?? I spose it would possibly screw up injectors or pump, if not what is the name of the lub additive and can it be purchased at most automotive dealers?
  #7 (permalink)
Old 08-21-2009, 03:22 PM
Biodiesel Guru
I myself would not use two stroke oil. Diesel Kleen is excellent and is available at most parts stores and truck stops.
__________________
FABMANDELUX.
Don.
  #8 (permalink)
Old 08-21-2009, 03:23 PM
Oh yeah, I've heard of that stuff - thanks
Tags
73 , diesel , ford , kerosene , mix , motor , oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
