Dist. Cap/Rotor Button...if not Motorcraft, what? - Ford Truck Enthusiasts Forums
Old 08-18-2009, 05:11 PM
geodiggr's Avatar
geodiggr geodiggr is offline
geodiggr is starting off with a positive reputation.
Hi all,
Need to replace my distributor cap and rotor button on my 1992 F150 w/ 5.0.
Cannot find Motorcraft distributor cap or rotor button at local parts houses. Dealership wants double what parts house wants.
If I had to pick another brand besides Motorcraft, which is the next best one to choose? Obviously, it needs to be cost effective and in stock as well...
Looking for any and all input...must get these parts tomorrow.
Thanks,
Rick
Old 08-18-2009, 08:09 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Do you absolutely have to have Motorcraft? If not, then just see what your parts store has.
My parts store generally has a few different options- usually a 1 year, 3 year, or lifetime warranty. For something like a cap and rotor they usually only offer a 1 or 3 year warranty, and I go with the 3 because that's long enough to cover it until I replace it again.
See what else your store can offer you in terms of warranty and cost and make your decision based on what you need. Personally I don't get hung up on name brands when it comes to basic tune up parts- as long as there's a warranty on them that's all I need.
Old 08-19-2009, 02:20 AM
rainbowATF rainbowATF is offline
rainbowATF is starting off with a positive reputation.
I bought an ACCEL cap and rotor from Advance Auto, because it had the brass contacts, as opposed to the aluminum contacts in lower cost parts. Its worked very well for the last 10 months.
Old 08-19-2009, 03:30 AM
Dirt racer's Avatar
Dirt racer Dirt racer is offline
Dirt racer is starting off with a positive reputation.
Summit racing has the Ford racing motorcraft distributor cap and rotor for $44.95 part number M12106-B302. I run these same ones and have good luck with them. Hope this helps.
Old 08-19-2009, 06:37 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I get the MSD one that is available from Summit and Jegs as well as A'zone, Advance and Orielly.
I think the MSD is made better than the Ford Racing one. The MSD has brass contacts too. I believe the Ford Racing is aluminum.
I would not buy the cheapo stuff. I would rather have the Motorcraft parts. If you want Motorcraft, I bet Orielly can get it.
The Accel or Ford Racing stuff is good too.
Old 08-19-2009, 06:51 AM
sparrky81 sparrky81 is offline
sparrky81 is starting off with a positive reputation.
Quote:
This is what I use on all 5.0L that I work on. If I do a tune up it gets one.
Old 08-19-2009, 09:12 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
accel cap and rotor is a good choice.
Old 08-19-2009, 10:14 AM
mike460's Avatar
mike460 mike460 is offline
mike460 is starting off with a positive reputation.
I personally like the MSD 84083 cap (extreme duty, black in color, $27.95) and rotor 8070 ($4.95) available from Summit, Jegs, Barnett Performance, etc
Old 08-19-2009, 06:21 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
You only need a distributor cap that has aluminum posts on it. The best distributor cap would have pure copper posts because copper conducts electricity far better than aluminum, but this does not hold true for brass (an alloy of copper). Brass is in fact less conductive than aluminum but only by a small margin when compared to the conductive difference between brass or aluminum to pure copper. Though the brass lugs do look better than the aluminum, it just doesnt stack up conductively.
Old 08-19-2009, 06:36 PM
skaterbro's Avatar
skaterbro skaterbro is offline
skaterbro is starting off with a positive reputation.
Accel here too. Got them when i got the coil. Over a year now and still going strong.
Old 08-19-2009, 07:00 PM
Popa Tim Popa Tim is offline
Popa Tim is starting off with a positive reputation.
I used to grab the Weiland gold series (maybe it was welland) from Autozone but I'm pretty sure they're not carried anymore. I bought the remaining stock from mine when they were clearancing them out.
My thoughts are go cheap and replace it every year or go expensive and do it every 2... Your choice.
BTW Napa carries the MSD in stock around here.
Old 08-19-2009, 07:09 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
I've seen cheap cap/rotors look worse with 15K miles than factory originals with well over 100K.
I currently have an MSD set on my 95 and it's holding up well with ~85K on it. It actually cost less than the parts store brand which I've had trouble with. I'll probably replace them in the near future. I think I'll go with Motorcraft this time though.
Would really appreciate help. Start issue lawsonej 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 05-31-2016 08:40 AM
New distributor ? BKM-WR3 1987 - 1996 F150 & Larger F-Series Trucks 10 04-05-2015 05:06 PM
PROCOMP 7004 DISTRIBUTOR CAP AND ROTOR FORDFAMILYOF3 Electrical Systems/Wiring 1 07-07-2011 01:20 PM
Can I replace the stator without removing the distributor??? THE BLUE HEAP 1987 - 1996 F150 & Larger F-Series Trucks 7 03-04-2010 08:25 PM
distributor cap 94XLTFLAREI6 1987 - 1996 F150 & Larger F-Series Trucks 12 02-25-2010 07:52 PM
Tags
302, aluminum, best, brass, button, cap, contacts, cost, distributor, ford, motorcraft, parts, pictures, racing, rotor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
