Replacing timing and cam on a 351m - Ford Truck Enthusiasts Forums
Old 08-18-2009, 05:06 PM
zoobiedoo zoobiedoo is offline
zoobiedoo is starting off with a positive reputation.
I am considering replacing the timing set and stock cam on a 351m with about 140miles on it that currently runs strong. Will I be able to just swap those out or will I have to do more than that. I have heard that because the bearings etc may be worn the cam may not fit properly.
I am just looking to get a bit more jam out of the engine for a lower cost - I don't need a lot of power as the motor will just be going into an old motorhome.
Old 08-18-2009, 06:56 PM
mustang81's Avatar
mustang81 mustang81 is offline
mustang81 is starting off with a positive reputation.
change the lifter too. The cam turn the half of the crank so the bearing wear slower than the crank.my 02
Old 08-18-2009, 08:40 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
Check lifter preload.
289 to EFI from 5.0 Mustang Engine craigibc Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 08-15-2010 11:14 PM
ford 400 cam and timing justforkicks 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 6 03-25-2009 10:33 AM
Cam swap 9299Fords 1987 - 1996 F150 & Larger F-Series Trucks 6 03-26-2008 03:55 PM
cam thomasmajewski 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 02-18-2005 01:32 PM
351M "straight up cam timing" palmrose2 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 20 10-24-2003 02:23 PM
Tags
351, 351m, cam, camshaft, engines, ford, lifters, motor, replace, replacing, sets, specs, stock, swap, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
