1977 Ford Dump Truck Steering gear box - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 08-18-2009, 01:30 PM
mey mey is offline
mey is starting off with a positive reputation.
Do you know where to send a 1977 Ford Dump Truck Steering Gear Box to be rebuilt? Or any place to purchase a rebuilt one or used one?
Thanks
Old 08-19-2009, 01:50 AM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
wmjoe1953 is gaining momentum as a positive member of FTE.wmjoe1953 is gaining momentum as a positive member of FTE.
Try Anderson Brothers, in Oregon. Very, very large selection of used truck parts. Get the numbers, or type off the box, and have a local NAPA look it up. They are still "VERY" available through NAPA, and if your local counter person can't help, then find a different employee, because that one is an idiot. I source all my older Ford parts through NAPA, and I can get about everything I could ever need through my NAPA. Just ordered a complete gasket kit for my Cat 1160....$95 my cost. Needed suspension brackets for my L8000 frame....my NAPA can get them in, for less than good used ones. Needed a master cylinder kit, and wheel cylinder kits for my '53 F-750. My local NAPAs had them on the shelves.....some in one store, some in another, got them all the next day. Needed parts for a '57 Ford 850 tractor. NAPA had them the next day. I will not use any place but NAPA for my hard to find parts for my old trucks, escept for, obviously, restoration specific parts.
1977 to 78 steering swap Thesteeleboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-12-2016 12:05 AM
77 f350 brake bracket on power steering box tom42nm 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-08-2012 07:56 PM
Steering gear box coreyws 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 03-25-2008 09:56 PM
Dump Truck Steering Box in f100? peteleoni 1961 - 1966 F-100 & Larger F-Series Trucks 11 11-06-2004 08:35 PM
Power Steering Conversion none 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-02-2000 01:51 PM
Tags
1977, 750, box, cylinder, dump, dumptruck, f750, ford, gear, large, master, parts, power, steering, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
