So after my trucks saw its first Michigan winter, it has developed some rust (around the cab lights/roof area, and windows). I want to try to fix (to the best of my ability) the areas before this winter. So how do you remove the outside lower trim/seal on the windows?
Ryan, your location shows IA. Did you move to MI?
Are you talking about the rear doors where the window seal meets the corner?
I have checked out several trucks with the same rust spots. Plan to touch mine up too very soon. Also need to clean up below the lower door seals.
Actually, I moved to IA in January - still missin' Michigan... I am talking about the window corner, only have one rusting so far, but it does seem to be common on these trucks.
