Whats the Best year of the 300-6 cylinder to replace my 240 with? - Ford Truck Enthusiasts Forums
Old 08-18-2009, 12:10 AM
overlandexpress's Avatar
overlandexpress overlandexpress is offline
overlandexpress is gaining momentum as a positive member of FTE.
I just bought a 66 shortbed with a tired 240 six in it and a 4 speed, I found a running 300 six out of an 84 van that has a 4 speed, will the 84 300-6 fit into the 66? will there be any wiring, bracket or other issues I need to know about? is the 84 a good year of the 300-6? any help would be appreciated. Here's a picture of the truck.
Old 08-18-2009, 06:46 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
swaeeeeeeeet!
John
Old 08-18-2009, 10:58 PM
Pickupmanx2's Avatar
Pickupmanx2 Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
NICE LOOKING SLICK!! The best year of the 300 is every one!! Yes the van one should bolt in, the newer ones will have electronic ignition, and once you rid it of all the crap, it is a great engine! Welcome, and nice slick!
Old 08-19-2009, 12:40 AM
Think I will install the 300-6 in the 66 and drive it while I build the 64 the way I want to. Here's a picture of the 64 lowered with mono leafs, I pulled the gas tank and had it flushed and just got the new filler hose and fill neck rubber grommet which I will install tomorrow.
Old 08-19-2009, 01:26 PM
SJ Bikesaws's Avatar
SJ Bikesaws SJ Bikesaws is offline
SJ Bikesaws is starting off with a positive reputation.
The 84 motor should be great. And the ignition if you can get it, the module and pickup has three more wires than the points system, and WAAAAAY less messin with.
Old 08-25-2009, 11:04 AM
unibody62's Avatar
unibody62 unibody62 is offline
unibody62 is starting off with a positive reputation.
Seems like that van engine may have a different Oil pan on it, but I could be wrong. sometimes they have to fit the crossmembers just right.
Old 08-25-2009, 06:05 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
A 300 6cyl. with dual carbs, a custom intake manifold, and twice pipes would would be
bitchin' man. That is a sweet lookin' truck. Dan.
Last edited by Parts Guy Wyatt; 08-25-2009 at 06:08 PM. Reason: SPELLING!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-26-2009, 07:35 PM
When you don't want one there everywhere but when you want one....
Soooo.... the Van 300 six was spewing oil everywhere and was a commercial van that had been abused and had lots and lots of miles so I decided to skip that purchase, then a guy calls and says he has a good running 1976 300 six with a C4 trans that he will sell me for $100 but he lives 150 miles away, I call him back and he says he is coming to my area today and can bring it with him so I am thinking HEY for $100 I'm in... and we agree on a meeting place so I load my cherry picker on my trailer and around 4:00 I give him a call to go meet up with him and he says he wrote my number down incorrectly and had no way to reach me so didn't bring the motor with him! OH WELL...whats a guy to do?
AND the 300-6 search continues...................
Old 08-26-2009, 08:59 PM
oldblu oldblu is offline
oldblu is starting off with a positive reputation.
There seems to be a lot of those engines available. If you are going to go to the trouble, I'd bide my time and try to get a nice one. I have a 240 in my current truck and it seems like it has all the power for what I use it for. I used to have an F250 with a 300 and COM. That truck was a dog! I blame it more on the 3/4 chassis and the COM than the motor.
Old 08-27-2009, 05:36 AM
jowilker's Avatar
Heard that one before. Always on a super deal, too.
John
Old 08-28-2009, 02:46 AM
unibody62's Avatar
Quote:
You're right not to blame the 300! I have had both 240 & 300.... the 240 was not near the engine that the 300 is. Well they were 30 years apart in age, but still the same basic engine.
Old 08-28-2009, 10:00 AM
Flyn66dtmn Flyn66dtmn is offline
Flyn66dtmn is starting off with a positive reputation.
hey overland, nice lookin truck. hey a coupla things to do if you're putting in a newer engine. try your best to get the motor mounts and the brackets for installing the alternator and power stearing ( if you are doing the conversion. ) I have done three trucks in the last five years ( putting in newer engines) and there are some design changes in the bolting patterns. same engine but the brackets from a 66 wont bolt to a 85. different design in the bolting pattern on the water pump and front of heads. i suppose a lot of it has to do with smog controls and whatnot. if you're gonna put in the electronic ignition try and get all the wiring with it. will save you a bit of time trying to find it. or an extra 50 bucks to buy it new. Dutch
Old 08-28-2009, 09:30 PM
tmd42024 tmd42024 is offline
tmd42024 is starting off with a positive reputation.
Ford 300 I6 Engine Swap
I have a topic that is very similar to Overland's question regarding the Ford 300-I6 engine swap. My particular application is a '77 wood chipper project with a Ford 300-I6. The previous owner of the chipper managed to get water in the engine; as a result, the valve train rusted up. With the cylinder head removed, a close examination of the cylinder bores reveals that they too are showing signs of rust and pitting. Rather than just changing the cylinder head, I think it is best to find a good used engine replacement for the chipper.
In my new search for a replacement engine, I took a look at the hp, tq, and rpm specifications for the 300-6 for the years '65-'96. The specifications indicate that the best torque and power ratings correspond to the below listed years:
'65 - '72 (283 Ftlbs @ 1600)
'87 - '93 (265Ftlbs @ 2000)
'94 - '96 (260Ftlbs @ 2000).
(Please note - the current '77 300-I6 engine in the chipper has approximately 223Ftlbs @ 1600).
Since I can find '77 & up 300-I6 engines at a local salvage yard -and- I would prefer an engine with higher torque ratings, I'm thinking of picking up a '87-'93 engine for the chipper. Of course, the engines that correspond to the late model ('87-'93) years are designed primarily for fuel injection and electronic ignition systems. As a result, I suspect that there would be some performance drop when a carburetor and distributor is installed on an EFI engine.
My questions are the following:
-Has anyone installed a late model 300-I6 with EFI and electronic ignition and then converted it back to a carburetor and distributor?
-Will the distributor and intake & exhaust manifold from the '77 bolt to an '87-'93?
-Does anyone know if the performance gains for the '87-'93 are primarily due to the EFI & electronic ignition?
I appologize for posting my Ford engine - chipper question this in forum. I hope the responses from the members will also benefit Overland and other Ford Truck enthusiasts that have similar questions.
Thanks in advance!
Old 04-14-2013, 04:13 PM
fstowwrench fstowwrench is offline
fstowwrench is starting off with a positive reputation.
chipper
Get a low pressure universal electronic pump,have a air grinder with a carbide rasp (just in case you may need to oval out a hole slightly)and make it work we here in western NY have done this type of things many times.
Old 04-14-2013, 05:15 PM
jowilker's Avatar
fstowwrench Welcome to FTE & the Slicks forum
know you want to kick in but a 4 year post has a lot of dust on it.
John
Old Offenhauser ad for the 300 six manifold overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 3 10-29-2010 11:51 AM
New 300 six installed and Ima driving her. (Pic's) overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 10 02-15-2010 10:42 PM
Hello From Coeur d'Alene...1966 F100 Shortbed overlandexpress Idaho Chapter 5 10-31-2009 08:02 AM
Distributor Vacuum ported? also whats average vacuum reading? overlandexpress Ford Inline Six, 200, 250, 4.9L / 300 7 10-19-2009 11:45 PM
Pictures of the engine pull overlandexpress 1961 - 1966 F-100 & Larger F-Series Trucks 11 09-12-2009 04:10 PM
Tags
240, 300, c4, cyl, cylinder, engine, find, ford, fuel, hp, injected, intake, specification, specs, torque, van, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
