Replacing a 88 F250 Ignition Switch Help - Ford Truck Enthusiasts Forums
Old 08-17-2009, 07:44 PM
Point Blank Point Blank is offline
Point Blank is starting off with a positive reputation.
88 F250 ignition switch is bad.How do i replace? Do i need to pull the steering wheel?
Old 08-17-2009, 09:30 PM
rowdyredneck's Avatar
rowdyredneck rowdyredneck is online now
rowdyredneck is gaining momentum as a positive member of FTE.rowdyredneck is gaining momentum as a positive member of FTE.
Are you talking about the lock cylinder itself, or the electrical switch? I'm assuming you mean the cylinder. If you have a tilt wheel it's simple, turn the switch to the run position and insert a small punch or phillips screwdriver through the hole located on the bottom side of the column, directly under the lock cylinder. Push in to compress the pin, then simply pull it out. If you do not have tilt, you'll have to pull the steering wheel to gain access to the release pin...otherwise the procedure is the same.
What exactly is it doing? It's very common for the switch actuator to break on tilt columns, which is an entirely different procedure that involves disassembly of the column.
Old 08-18-2009, 07:42 AM
This column does not tilt.
No radio / wipers if the key is in the acc position.If i jiggle key radio comes on wipers work.
While truck is running the radio / wipers will not work when i hit bumps,etc.When i jiggle key they come back on.
Someone told me my switch is probably bad,or the electrical connetor burned causing short? I have smelled not burning smell though?
Key seems very easy to turn now compared to before these problems.
Old 08-18-2009, 07:57 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Rowdy gave you great directions on how to change the ign lock barrel. However from your last post I would think you have a bad ign switch. You will find the ign switch on top of the steering column and under the dash. It is connected back up the column to the key switch by a rod.
Check the wiring connector to it first.
88 F250 Steering Lock Actuator Replacement How-To cadudite 1987 - 1996 F150 & Larger F-Series Trucks 1 04-13-2016 12:58 AM
88 F700 ignition switch 88F700 Large Truck 2 08-13-2014 10:14 PM
Ignition problem harbor97 1987 - 1996 F150 & Larger F-Series Trucks 4 11-10-2013 06:19 PM
88 F250 4.9 starting problems mike88f250 1987 - 1996 F150 & Larger F-Series Trucks 8 02-14-2011 10:20 PM
88 F250 Steering Column SHW300 1987 - 1996 F150 & Larger F-Series Trucks 7 02-14-2010 08:08 AM
Tags
1996, 88, 92, 96, changing, cylinder, f150, f250, ford, ignition, lock, replace, replacing, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
