Leveling Kit Install
IS the main reason for these lifts to ease rubbing of bigger tires or is it to look cool? Is there a benefit other then the rubbing? I think my truck handles like a top heavy boat compared to my old GM's. Why would I make it worse? Not trying to just wonder what the difference is.
Yeah I had access to a torque wrench that I could use that went up high enough.
I believe the lower nut was 250 ft/lbs.
Mainly people get a leveling kit to gain clearance in the front to fit bigger tires. Occasionally people will put them on just for the looks but my reasoning was to fit the bigger tires that I put on.
Someone with more experience will have to step in though.
Stock rims are 7.5 to 9 inches in width depending on which model we're talking about. Most are 7.5inches. I wouldn't put a 305 width on a 7.5inch rim...too much risk of in becoming unseated at the sidewall.
This is an XLT truck with the 5 spoke wheels with the whitish finish on them. I have seen a few 295/70 sizes available also, but that probably wouldn't look much different. Thanks for all the input.
I did the 2" a couple of weeks ago and it's just enough on my '06. If I had done the 2.5" I think it would have been too high.
The higher clearance is nice. I put it to use this weekend when I had to hop out of line at the local JackInTheBox. Evidently there was some hash brown disagreement and a couple of cars full of roofers blocked off the exit to the drive thru so nobody could move. After waiting and being trapped inline for 10 minutes I hopped the curb (which had no earth on the other side of it) and drove through a field...I didn't even bottom out on my skid plate.
#28
#29
Have been thinking about a leveling kit myself and the question I have is if I put one in how much will the back end sag with my ATV in it (about 500lbs loaded)? I have read a few threads here where people do the front to level the truck and then turn around and put spacers/blocks in the back. is this just a cheaper way to lift the whole truck?
#30
This auction says if I put these spacers on my truck I can fit up to 33x12.5's is this correct?
http://cgi.ebay.com/ebaymotors/SUSPE...Q5fAccessories
Thanks,
Chris
Thanks,
Chris
