My gas mileage is great - 19 MPG combined
#31
I get 11.3 (first tank measured after a motor swap, so I'm hoping it goes up). I'd love to see 14. :-)
I've got one of the Haynes F150 customization books. Lots of pretty pictures. One mod they suggest that I have every intention of implementing is a vacuum gauge. Eyeballing engine load all the time has the effect of making you let off the gas pedal to keep that gauge in the zone where you use less fuel. I figure the install is gonna run me about $60 to make it pretty and do it right. If I can get to the figures you guys are talking about, or even get close enuf to sniff those figures, I'll be completely satisified.
#32
#33
oil companies are just now switching to winter blend on the gasoline. plus the ambient temps are now about 45-50 degrees, not 80. What that means is your milage will drop 1.5 - 2 MPG for the winter. Happens every year in the upper midwest. Dont know about the southern states. You dont get 17-18 in the winter, you get 15.5 MPG.
#34
#35
Yep i have if you read my earlier posts... at least I tried no fan at all (should be even better mpg than runnng electric fan). Multiple tanks of fuel and no noticable gain. There are many reasons they have used electric fans. What I am saying is on a truck they arent going to make a 1+mpg improvement. And racers use them since they can control them, you can shut them off for max power and also they cun run to cool the motor after the engine is off. I'm not saying there isnt any advantages, just that expecting a noticable gain in mpg is bs. I am sure the racers put them on there for mpg.
For the record I have got in the 19's. However I never claim that since I cant repeat it easily. To many folks get something a couple times and claim thats waht they get. Not saying that your not averaging that high, its great if you really are (hadn calc of course), but a true combined driving consistantly averaging that high...
#38
03 f150 4x4 4.6L with 33" tires. 3.55 gears. I get 12-14 highway and 10-12 around town. K&N filter, throttle body spacer, and Flowmaster exhaust.
Question? Even when I start my truck, the fan is on. Isn't it supposed to be a clutch type? Is it supposed to go on only when the engine is hot?
Also, I put a flex fan on my old mustang. The angle of the fan blades would lesson with the speed of the engine. Anyone heard of using these on an f150?
#39
The fan clutch is based on rpms. After a certain amount of rpms - the clutch will disengage. It has to run at slower speeds and at idle or the A/C condensor would not get air flow and would not be able to cool properly.
Don't know about the flex fan. I do know you can do a single electric 16" fan from autozone and a controller for $100.00
#40
Some work on temperature also.
Straight from Wikipedia and I couldn't have said it better.
A fan clutch is a thermostatic device that exists as an integral component of certain automotive cooling systems. When the engine is cool or even at normal operating temperature, the fan clutch partially disengages the engine's mechanically-driven radiator cooling fan, generally located at the front of the water pump and driven by a belt and pulley connected to the engine's crankshaft. This saves power, since the engine does not have to fully drive the fan.
However, if engine temperature rises above the clutch's engagement temperature setting, the fan becomes fully engaged, thus drawing a higher volume of ambient air through the vehicle's radiator, which in turn serves to maintain or lower the engine coolant temperature to an acceptable level.
Most fan clutches are viscous or "fluid" couplings, combined with a bi-metallic sensory system similar to that in a thermostat.
#43
#44
