2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
oil plug broken please help!
Old 08-18-2009, 10:35 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Well i was going to change the oil myself and im guessing the thread on the pan or the bolt are worn because the bolt spins in both directions but it wont come out. What can i do to get it out?
Old 08-18-2009, 10:49 PM
berry1234's Avatar
berry1234
berry1234 is offline
How many miles do you have? If under warranty I would take it in and have them fix it. It's pretty hard to ruin a drain plug. The factory may have cross threaded the bolt on.
Old 08-18-2009, 10:52 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
well i just bought it, i am going to take it to the dealership tommorow and see if they can fix it
jdm5630's Avatar
jdm5630
jdm5630 is offline
its out of warranty
Old 08-19-2009, 07:18 AM
gddyup's Avatar
gddyup
gddyup is offline
The pan threads are most likely stripped. The pan usually strips before the plug does. To get it out you can use a screwdriver or something flat like that and "wedge" it under the plug as you turn it. That will usually help get it out. But, if the pan is stripped it depends on how bad it is as to whether or not you'll get a plug back into it. You can find pan taps that *might* be able to clean the threads up, but again it depends on how bad it is. You can also by replacement self-tapping plugs that will create their own threads in a damaged pan but they are pretty "backyard mechanic" and don't always work. I've seen pans "repaired" both ways and people have gotten along fine but either of those fixes would be my last choice solution. The best choice would be a new pan and plug but moeny factors will weigh heavily on that decision.
Old 08-19-2009, 10:27 AM
berry1234's Avatar
berry1234
The pan and gasket online can be had for around $120 for both. Best bet would be buy these along with a new drain plug if the dealer you bought it from won't help you out.
clest82
6.7L Power Stroke Diesel
05-12-2017 04:39 PM
tanagerhills
1997-2006 Expedition & Navigator
05-11-2017 09:41 AM
docskid
08-09-2015 09:01 AM
Paulsf350sdcc
06-09-2014 04:03 PM
KG in CT
11-06-2013 10:11 AM
Quick Reply: oil plug broken please help!
