v-10 cylinder head id - Ford Truck Enthusiasts Forums
Old 08-16-2009, 09:46 PM
02f-350 02f-350 is offline
02f-350 is starting off with a positive reputation.
How do you know if you have a short threaded cylinder head or a long threaded cylinder head? I have a 2002 f-350
Old 08-17-2009, 11:10 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Here's the info:
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Old 08-17-2009, 11:11 AM
Krewat's Avatar
Here's the info:
Original process:
Old 08-17-2009, 05:26 PM
Thanks, I have a v-10 in my truck and just started to hear a ticking sound from the passenger side of the truck and it only has 48,000 on the motor. I stopped driving it and am hoping to check the plugs torque this weekend. I was hoping I had the long threaded heads.
Old 08-17-2009, 08:09 PM
Destroya Destroya is offline
Destroya is starting off with a positive reputation.
Hows your exhaust manifold studs look? Any missing or loose?
Old 08-17-2009, 11:28 PM
Havent looked into the exhaust manifold area yet. Been getting home late and it's to dark to work on. I will start on truck thursday morning. Thanks for the heads up. I am hoping it's something simple.
Old 08-19-2009, 11:01 AM
myblkex's Avatar
myblkex myblkex is offline
myblkex is gaining momentum as a positive member of FTE.
That's how mine started .... Ticking coming from the passenger side. I checked the first 3 closest (easiest ) plugs and they were fine. I was running late and didn;t get to the back 2 --- next day --> guess which one blew ! $300 tow to Ford for them to cover it under warranty ....
Definitly check them and take a peak at the studs as welll... Mine is a 2000 and being in the northeast doesn't help the rust factor either... Mine's got a couple missing - but still not a real problem... will look at getting them replaced in the next few months while still under warranty
good luck !
Old 08-20-2009, 08:29 PM
Alright guys, I just got the best news to report. After trying to find the ticking noise I started with the many suggestions from this site, start at the plugs was what I did. Well guess what, it was a plug. I was lucky enough to hear the ticking soon enough and stop driving it. The plug was just about hand tight. I removed it carefully and no threads had any aluminum on them so I feel pretty safe that I was lucky enough to catch it. So I torqued the plug back down, and the ticking is gone. I want to thnk the people that posted on my thread and also for the awesome site. Thanks Todd
Old 08-20-2009, 11:33 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
How do you know when your engine was built if the sticker on the side of the block is gone?
Old 08-21-2009, 10:19 AM
Krewat's Avatar
Quote:
Check the door sticker, and subtract about 30 days for a guesstimate
If you get an OASIS report, you can at least find the engine serial #, but that's about it.
04-08 5.4L 3V PROBIKE101 Modular V8 (4.6L, 5.4L) 0 05-14-2016 09:21 PM
GT40 Heads on Fleabay fordf350man 1987 - 1996 F150 & Larger F-Series Trucks 5 01-06-2016 05:04 PM
Cylinder head question?? TucsonBogger 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-08-2013 11:02 PM
Rebuild heads Vs. Buying new heads NBC-Steve 1973 - 1979 F-100 & Larger F-Series Trucks 26 01-24-2011 07:49 AM
Oil Consumption -- All of a Sudden thollist Modular V10 (6.8l) 9 08-05-2009 09:07 AM
Tags
10, 46l, 68, cylinder, cylinders, engine, ford, head, heads, order, performance, sound, ticking, trucks, v10, wep
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
