78-79 ford dana 60 front axle
Sorry man, took a while to put everything away today. Long day of wheeling.
Anyway, the last if the D60 front axles that you have is a decent axle, but fits just barely above the super duty axle as far as desireability goes. This axle that you have is a ball joint axle, which is strong, but lacks the option of a bolt on steering arm like a king pin unit would. This means that an entire new knuckle would be required.
That being said, this axle also has the short driver side axle tube and the diff that is offset to the dirver side further than the 78/9 axle, limiting this axle to later model trucks, or needing some mods to make it work under a different vehicle.
All Dana 60F apring perches are cast into the driver side diff, but the diff is closer to the knuckle on the later model axles. Trying to use this in a vehicle with a narrower frame might place the spring right on top of the diff itself. Real hard to put a u-bolt around the diff ltself, so this makes this axle a little less desirable.
78/9 axles can be installed into later trucks, but the later axles are very difficult to install into eariler ones, or vehicles with narrrow frames, without some fancy fab work.
FWIW, I can get ball joint axles for about 500 hundred bucks in my area, and SD axles for about the same.
Hey f350...sorry I jumped your **** on the other thread I was a bit cranky that day...
Heres some prices We've paid for dana 60's...
My brother just scored a deal. he found a 1988 460 f250 with a lift somewhere around 8-10" and a dana 60(balljoint) front fitted to it for 800. the guy was moving and blew the engine.
I had bought a 1990 f350 460 from cook county (chicago) parks department for 1400 off ebay. The highest bidder under me was a junkyard. I bought it for the kingpin dana 60 and it was incredibly rusty but when I picked it up it had new exhaust and cat from the manifold back and brakes...not just new pads, new drums rotors calipers lines everything I just put a battery in it and drove it on the trailer. One of the few ebay wins that was better than expected. they had it in the shop evewry 2k miles for whatever it needed. I was offered almost 3k for it back here in Omaha and let it go after getting a year out of it. Only sad part about the story is an hour after paypalling the money in for the f350, A wrecked 1998 E450 ambulance with 30k actual miles popped up on Ebay and I didn't have the cash to bid. I hooked my buddy up and he won the auction for $1200. It had a 7.3 powerstroke and the OD tranny had the parking brake which meant it was a 4x4 tranny. BOOOO missed on that one.
I had been looking for a dana 60 for my 4x4 van and was wanting to put a diesel in it too.
I had looked at alot of dana 60's like yours and alot of them were incomplete missing the brakes and steering and some the hubs. By the time I was done I would have spent close to 2k on one and I could have bought a brand new dana 60 through Quigly for around 3k. $900 might sound like alot with some going for $500- $700 in bad shape but if yours are complete I think that's a fair price.
When I bought that 1990 f350 I was thinking the D60 kingpin axle with the steering and springs and all was worth at least a grand -$1200 and I was happy to have it.
hope that gives you some faith in your price.
another thing I remember is there was a guy in Jersey that had a bunch of f450 dana 60 fronts and was getting them shipped to anywhere in the us for $250 airfreight but it had to be crated. He claimed airfreight was about half to 2/3rds of truck freight through old dominion or yellow.
75' F250 Front axle/power steering
Hello Fellas, I'm pretty new to this and it has been years since I have done any automotive work. I recently bought a 75' F250 4x4. It needs a ton of work on the front axle: Bearings, knuckle seals, etc, lol. I've talked to several people and of course get different opinions. As well, I'd love to add true power steering instead of assist. I, too, have heard of going with a 78'-79', but I have had a 4wheel drive shop run something else by me. They say that if it was their truck, they would put in a 93'-97' Dana 60 in. Preferably a 93'-94'. Does anyone have any imput on this subject?? I do appreciate any advice. I'd like to know the best way to go before I start spending.
Those later axles are easier to come by and are a lot cheaper, but the Dana 60 changed from kingpins (stronger) to ball joints in 1992 (not as good). Also the the spring pad spacing changed in 1980 so 1980 and up Dana 60 will not simply bolt on- only the '79 and down will. You would have to move your springs outboard. If your are planning on going with a coil sprung front then a later model axle could work out just fine.
A 4 wheel drive shop could make lots of money trying to fab in a later model D60
hi im new to this forum and actually joined because of my current question that i can not answer no matter how much research i have performed. i have stumbled upon a 1978 ford dana 60 front axle in immaculate condition locally for $250 which is an amazing deal for a complete axle and i was wondering if it would bolt straight up into my 1984 diesel f250 with out any modifications? and if not how difficult would it be to to modify it? sorry if i intruded on someone elses thread it just seemed like the people in this thread really know what there talking about and i may buy the axle today if i get the right response please help a fellow ford owner out i would really appreciate it.
#29
#30
- Where is local?
- Can you prove, rather are you sure it's a 78-79 High Pinion King Pin D60?
- I'll more than double your paying price, dependant upon completeness & shipping
- I'm in the Atlanta Georgia area.
email me @ rsfabrication@gmail.com
