how much paint? - Ford Truck Enthusiasts Forums
how much paint?
Old 08-15-2009, 08:59 PM
deere55's Avatar
deere55 deere55 is offline
deere55 is starting off with a positive reputation.
how much paint?
does anyone know about how much paint it would take to do one coat on a 87-91 f250/350 ?
Old 08-15-2009, 09:12 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is online now
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Are you doing any body work? Is it the same color as the original color? Are you doin the door jams and inside the bed? Reg cab, x cab , crew cab?
Old 08-15-2009, 09:24 PM
deere55's Avatar
its a 1990 f350 reg cab srw. ill do inside the bed but not the door jams. and im thinking of changing from white to black. dont think it needs any body work.
Old 08-15-2009, 09:34 PM
You have no dents or rust!? I am envious. You will need to prime the truck before changing colors(at least gallon of prime) You are going to leave the door jams white on a black truck? Have you ever owned a black vehicle( they suck) at least 1.5 gallom to do the outside of the truck and the inside of the bed. Are you going to clear coat?
Old 08-15-2009, 09:39 PM
deere55's Avatar
yeah im going to clearcoat it. but theres no point clearcoating inside the bed (is there?)
i might make it forrest green or somthing too, idk yet. the door jams seem like they would be a pain to do, are they?
im just trying to get a ballpark on supplies and pricing.
and whats wrong with black? ive never had it, i just think shiny black looks awesome
there isnt much dents or rust, no. nothing that would really be that big a deal to fix
Old 08-15-2009, 09:57 PM
Black and almost every dark color shows EVERY imperfection(dirt(in the paint), rust,dents) and looks dirty 30 seconds after you just washed it. And YES. it would look like **** if the door jams were not none
Old 08-15-2009, 10:35 PM
4BT-F150 4BT-F150 is offline
4BT-F150 is starting off with a positive reputation.
If the paint is original and in good shape, there is no need for primer. Just scuff the surface and spray over it, the factory paint will act like a primer.
Old 08-15-2009, 10:41 PM
deere55's Avatar
ive never painted a vehicle before, what would i have to do?
Old 08-15-2009, 11:04 PM
If you are going over the original white, remove all the trim,grill,lights,glass anything you can. You will need to wet sand w 400-600 grit paper. Then clean the clean the whole truck w a wax and grease remover. Tape off anything you dont want paint on, wipe off the truck again and start painting.
As for not clearcoating.... If you use a 2 stage paint, you hve to clearcoat otherwise it will come out like black primer and have no protection againgts the elements
Old 08-15-2009, 11:16 PM
Quote:
The plan for my F150 is to scuff up the factory paint with a scotchbrite pad, remove or mask off windows, trim, mirrors, grille etc. and pay a local guy to spray 2 or 3 layers of single stage paint. I will be using a single stage urethane paint from TCP global. I've heard good things about it and the paint, hardener, and reducer is under $100 shipped.
Some will argue that the only way to paint is to take the vehicle down to bare metal and go with base coat/clear coat. But I can't justify the $3-4K it would cost to pay a shop to do this.
Old 08-16-2009, 07:26 AM
rowdyredneck's Avatar
rowdyredneck rowdyredneck is offline
rowdyredneck is gaining momentum as a positive member of FTE.rowdyredneck is gaining momentum as a positive member of FTE.
Quote:
Ditto on that. I painted my '84 black and it's never clean....it's dirty as soon as I finish washing it. It looks awesome during the extremely limited time it actually is clean, but I don't think I'd ever choose that color again.
Old 08-16-2009, 09:47 AM
goodB0Y goodB0Y is offline
goodB0Y is gaining momentum as a positive member of FTE.
I would never paint a vehicle black again... looks great when it's clean... lol
How much to paint it? slenser Excursion - King of SUVs 20 01-27-2012 05:59 PM
how much paint for motorcycle??? z 97ford1 Paint & Bodywork 17 05-19-2009 10:09 AM
Paint shaballa72 Paint & Bodywork 4 03-25-2006 10:09 AM
How much paint? pfogle 1987 - 1996 F150 & Larger F-Series Trucks 5 03-15-2003 04:57 AM
how much paint to paint frame? 85351ho Brakes, Steering, Suspension, Tires, & Wheels 3 05-01-2001 04:55 PM
Tags
1990, 1996, 86, 94, color, cost, f150, f250, f350, ford, needed, paint, painting, truck, wax
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
