ACT/ECT testing
Old 08-16-2009, 08:15 AM
geodiggr's Avatar
geodiggr
geodiggr is offline
ACT/ECT testing
Hi all,
Trying to test my sensors this morning. The truck is at ambient temperature, should I still be able to get resistance readings on these two sensors?
If so, by the same token, I should be able to take one out of the box and get resistance readings as well...correct?
Thanks,
Rick
Old 08-16-2009, 09:09 AM
subford's Avatar
subford
subford is offline
Yes you should.
I just checked an ACT sensor and it read about 25,000 ohms.
I will look for my spare ECT sensor but seems to be hiding right now.
The ECT should also read about 25,000 ohms.
Old 08-16-2009, 10:55 AM
Conanski's Avatar
Conanski
Conanski is offline
See here... http://www.fordfuelinjection.com/
Both these sensors can be tested with a DMM and heated water for the ECT and a hair dryer/heat gun for the ACT, the resistance readings will change as the sensor heats up from ambient.
ExPACamper
11-01-2016 01:51 PM
Jayme Duty
02-16-2011 04:49 PM
milkman22
1983 - 2012 Ranger & B-Series
04-21-2009 08:07 AM
jerzydiver
11-05-2006 10:34 PM
joners
04-02-2006 02:29 PM
Quick Reply: ACT/ECT testing
