'89 F250 Flexplate replacement - Ford Truck Enthusiasts Forums
Old 08-15-2009, 03:09 PM
Ace of Spades Ace of Spades is offline
Ace of Spades is starting off with a positive reputation.
Hello Everyone!
Have a bad flexplate that I need to replace but don't have any leads on where to pick one up other than the Ford dealership from my searches around the local parts stores. Does anyone here have an online store that you know of where I can get one of these for my 7.3L that won't cost me an arm and a left leg? Any source would be great really as I need to get this truck up and running. Also, any tips on how to get this thing out or a "Good" repair manual as my Haynes is not very detailed. I'm sure I could figure it out, but I just don't want to take forever getting this thing out and messing something up in the process. Thanks in advance for any help you can give me!
Ken (Ace)
Old 08-15-2009, 11:44 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Ace of Spades,
Welcome to FTE and the IDI forum.
What are the specifics on your ride?
2X or 4X
E series or F series
C 6 or E4OD
Old 08-16-2009, 12:54 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Replace the ring gear if that is all that is bad much cheaper than a whole new flexplate.
Old 08-16-2009, 08:29 AM
Quote:
Originally Posted by Dave Sponaugle View Post
Ace of Spades,
2X or 4X
C 6 or E4OD
Thank you, Dave!
My Specs:
1989 F-250 4X4
7.3L Diesel
Automatic Trans. - I have the "Overdrive Cancel Switch" so that would mean I have the E4OD, right? (P-R-N-OD-2-1 shifter pattern)
Quote:
Any idea where to pick one of these up? Am I stuck with getting one from the dealer in my situation???
Thanks guys for the replies!
Ken (Ace)
Old 08-16-2009, 10:12 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Online dealers usually are much cheaper.......50% off usually...... it is also called a "drive plate" on Ford pages.
Old 08-17-2009, 12:46 AM
I've been having trouble finding a place that sells what I need online but check out these sites below.
This is the drive plate you were talking about, PLC but they don't have one for the 7.3L.
http://www.trademotion.com/partlocat...89&catalogid=1
Here's the ring gear, but from what I'm seeing on my flex plate, it's all one piece or at least looks like all one piece so I'm not sure what it is that they are selling and how it would be used. Unless it has to be welded on and then balanced, not sure.
This is what my flexplate looks like essentially. How can one charge so much for that??? Is it because it isn't in high demand or what?! Outrageous! There's got to be a better source for this thing or at least something a little cheaper. Can't afford that much, not at the moment at least. Argh!
http://www.atsdiesel.com/ats2/produc...et_Flex_Plates
352 FE - C6 flexplate?? NDChris 1961 - 1966 F-100 & Larger F-Series Trucks 1 03-13-2015 11:01 AM
289 / AOD Flexplate and Starter Selection Holehawgg 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 05-27-2012 11:34 AM
460 Vibration Problem cjf5150 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 05-02-2006 01:21 PM
Balancing issue... Muldo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 11-15-2005 07:43 PM
Tags
1988, 1999, 69, 73, 86, diesel, e4od, f250, flex, flexplate, ford, plate, powerstroke, repair, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
