Solenoid/starter problem? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-15-2009, 12:18 AM
Erikpdx Erikpdx is offline
Erikpdx is starting off with a positive reputation.
Hi,
Truck would not start with a jump after it died. Put a new battery in and it turned over with a stuggle. Turned it off and back on and barely made it the second time. Drove home and it didn't start the next morning(battery was drained). Have tried to jump the new battery a few times and all I get now is the one click when I turn the ignition on. I was wondering if it could be attributed to the a/c belt? i was using the ac a lot in the previous weeks and thought maybe the excess use could have contributed. Or is it more likely a starter/solenoid problem?
thanks!
-Erik
Old 08-15-2009, 12:31 AM
...or could it be the alternator with the quick drain of the battery? lights/radio still function.
thanks again.
Old 08-15-2009, 09:55 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Is the "new" battery a new battery, or just new to you? When you remove the negative cable from the battery and then touch it to the post again, do you get a spark? There should be the teensiest of sparks for the juice to run the ECM, and keep the radio memory. If you get a healthy spark, you have something turned on, or shorted. In that case, remove the cables, charge the battery, and then find out what is drawing the current by pulling the fuses out, and then replacing them one at a time. The alternator could be discharging the battery if the diodes shorted, or the regulator failed.
tom
Old 08-15-2009, 10:11 AM
It's a brand new battery. It's getting charged from the place I bought it from this afternoon. Thanks for the idea with the fuses. Will give that a shot if I can figure out what fuse goes where thanks again.
Old 08-15-2009, 03:05 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Before you condemn the Battery, solenoid or starter, check the main battery cables and ground. Common problem areas and they feed the truck with battery power. Don't rely on a visual, used a meter (VOM).
Old 08-15-2009, 08:24 PM
Had a friend take a look at it and he suggested replacing the starter relay which i just did. Didn't do anything. So if I get a VOM. What do I need to test for? Or where more specifically?
Old 08-15-2009, 08:54 PM
aquanaut20's Avatar
Quote:
Look = visual...... maybe I didnt make myself clear.
You must be willing to perform some diagnostics, instead of throwing parts hoping for a fix.
Old 08-15-2009, 09:04 PM
I did that before I saw your message. Took a chance on a $22 part. I have an ohm meter now. Just wondering what I ought to be testing with the ohm meter? Does the battery need to be disconnected before testing? Battery cables and the grounding wire is attached btw.
Old 08-15-2009, 09:32 PM
aquanaut20's Avatar
Leave everything connected
VOM, set to 20vdc, RED on POS/Battery, Black= negative/ground
  1. Test battery, directly post to post (??.??vdc)
  2. Test Bat+ post to good clean engine ground (??.??vdc)
  3. Test +stud (upstream) starter solenoid to engine ground (??.??vdc)
  4. Test starter lug (BIG) to engine ground, starter activated (??.??vdc)
Report back,
Old 08-19-2009, 12:11 AM
Pulled the starter. Took it to an auto parts store and it turned out it to be the problem. Pain in *** getting it back in though! Sure felt good when it turned over that first time Thanks for the help guys.
-Erik
1980 F100 turn key, won't start then everything dies. Uncle Paul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-22-2014 10:33 AM
78 F150 Starting Issues Wooticus 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2013 12:57 AM
Starter problems wfearrington 2004 - 2008 F150 16 10-07-2008 10:03 PM
HELP! Battery dies after sitting! I think starter solenoid is at fault?! 76F250HighBoy 1973 - 1979 F-100 & Larger F-Series Trucks 9 11-01-2005 05:14 PM
Starter turns slowly jln_Wasabi Electrical Systems/Wiring 7 03-03-2004 11:36 PM
Tags
battery, drainscould, f150, ford, fords, jump, jumping, post, problem, problems, replace, solenoid, starter, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
