serpentine belt diagram??? 2002 7.3
Old 08-14-2009, 10:35 PM
B-Ryan 02's Avatar
B-Ryan 02
B-Ryan 02 is offline
Does anyone have a diagram for the serpentine belt?
Old 08-14-2009, 10:43 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
Should be one right in your engine bay. Drivers side near the front on a painted piece of steel. I know mine's got one there.
Old 08-14-2009, 10:50 PM
B-Ryan 02's Avatar
B-Ryan 02
It usually is but mine is gone.
Old 08-14-2009, 11:40 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Here ya go.
Single Alt setup:
Double Alt setup:
Stewart
Old 11-18-2021, 08:39 AM
DTexican's Avatar
DTexican
DTexican is offline
AC Pulley question
What are pulley numbers 3 and 8? I have a 2000 7.3L excursion single alt. my AC compressor when out and the belt tangled itself and made these pulley's pop out.
Originally Posted by Stewart_H
Here ya go.
Single Alt setup:
Attachment 204144
Double Alt setup:
Attachment 204145
Stewart
Old 11-18-2021, 09:10 AM
Sous's Avatar
Sous
Sous is online now
Received 4,460 Likes on 2,850 Posts
@DTexican , welcome to the FTE!
The answer to your question is the tensioner pulley set as seen below.
Old 08-14-2023, 05:40 PM
WNYPSDguy's Avatar
WNYPSDguy
WNYPSDguy is offline
Smile
So I learned something recently. The pic Sous posted is actually upside down from how it installs on the engine, but it shows something I didn’t know about until I pulled mine off. The little dark colored piece on the top of that pic is a “lock” for the tensioner. It is spring loaded to pop out once you get your belt in place. To use it, put a breaker bar in the square slot, take tension off the belt, reach underneath (remember its upside down from as shown), swing that piece up in place as is shown in pic, and release your breaker bar to lock it in place. Once you are done with routing the belt, a quick push on the breaker bar will release the lock and put tension on the belt. Happy motoring.
The following users liked this post:
btm991
6.7L Power Stroke Diesel
11-08-2014 06:32 PM
B_line66
08-22-2014 07:13 AM
phrog4821
Aerostar
12-22-2004 11:51 AM
dozerd12r
12-27-2003 09:15 AM
Quick Reply: serpentine belt diagram??? 2002 7.3
