Need GEN I lightning throttle cable - Custom Ducts
Hopefully you don't mind me posting the pics you sent. Since it's such a cool setup, figured others might like to see.
Did you go with the tfs-r because you didn't think the gt40 intake would be enough for the big motor or because of cost? It's a pretty cool looking intake. Does it come 90mm already or do you have to bore it out?
TFS-R makes two versions - 75mm and 90mm. I went with 90mm becasue of the Lightning MAF being 90mm. The GT40 lower does not have enough flow for a 408 (optimal). You would need to have it ported. I was debating going with a GT40 lower and a Downs Box upper, but the TFS-R still had the better bang for the buck. Actually you can get GT 40 on ebay pretty cheap, but I think a lot of them have been messed with and screwed up. TFS-R had the best all around specs for a truck as you want the power in the lower end, but the bigger intakes have shorter runners so TFS-R was better than say a Edelbrock EFI.
It runs waaay better than my original set up with Edelbrok truck EFI and the 61mm BBK dual TB.
What I like is that the 408 has good bottom end but the TFS-R comes to life at 40MPH and will still make power into the mid 5000 range. It is hard to believe that I have to let off the pedal as it feels like turbo kicks in at 40+
Hehehe, freekin' awesome! Definitely jealous; you haven't taken any video, have you? I want to do a smog legal 373w with a twin-screw. I have a KB 2.2L with a 75mm inlet which I've been told isn't sufficient in terms of size to feed a big stroker like a 408, but I'm thinking it might work pretty good with a small increase in displacement and around 10psi of boost on a 373.
For now I'm just building an N/A rollerblock with lightning stuff to get an engine swap tag for a 351w lightning motor in a 5.0 bronco.
I accept with information: the application list for the 'Accelerator Cable' for a 94 L, It shows the same cable working on broncos / normal fseries (twin tb trucks).
_________________
Argentina tours
_________________
Argentina tours
Millam
02-22-2016 03:04 AM
mnalightning00
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-24-2011 11:33 PM
