Ignition switch key tumbler removal - Ford Truck Enthusiasts Forums
Old 08-14-2009, 04:01 PM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
I having a problem getting the tumbler out of the ignition switch. I put the key in and turn it to ACC then put a drill bit into the hole and turn counter clockwise. It feels like something is grabbing the drill bit when I turn it. If I pull it out a little the key turns to the left past ACC but will not come out of the bezel, any ideas on why it would not remove?
Old 08-14-2009, 04:46 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Not sure, the purpose for the paper clip, or in your case, drill bit, is only to unseat the tiny check ball that's seated in the hole. Perhaps inserting the drill bit too far causing the tumble to bind and not allowing the tumbler to release and rotate. May try inserting just enough to release the ball while rotating the key counter clockwise. Keep in mind, needs to be in same position when installing. Anyhow, food for thought.
Old 08-14-2009, 04:50 PM
kjvforme's Avatar
I can get it to rotate past ACC and come out a little but will not remove all the way. I want to pull the switch from the bezel, but if tumbler is still in place other post state will not come out.
Old 08-14-2009, 05:14 PM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is offline
gritsngumbo is gaining momentum as a positive member of FTE.
Maybe try a small smooth nail or paper clip rather than the drill bit.
Old 08-14-2009, 05:18 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
With the key turned flat 9:00-3:00 it should pull out. It has to be turned flat to come out. I have always used a paper clip.
John
Old 08-14-2009, 05:22 PM
kjvforme's Avatar
I'll try the horizontal position and see what happens.
Old 08-14-2009, 05:39 PM
kjvforme's Avatar
I got it out, but not without damage. The cover for the tumbers posts must have come up some and was bent pretty bad on removal. It must have come up enough to not allow for it to just pop out. Some of the springs went when removed so it's time to order a new set tumbler and set for the door as well. Thanks for the replies
Rob
Old 08-14-2009, 05:45 PM
knibbeone knibbeone is offline
knibbeone is starting off with a positive reputation.
I just did about the same on my 64. My Napa had the ignition switch assembly with keys as well as door locks in stock. less than 60 bucks and all nice and shiny.
Old 08-15-2009, 12:02 AM
kjvforme's Avatar
Were the doors keyed to the ignition key?
Old 08-15-2009, 01:17 AM
no, i went to my local locksmith and he re keyed the ignition to match the door locks for 8 dollars.
Old 08-15-2009, 12:12 PM
Quote:
Rob
Suggest include the switch if have not done so. The tumbler should not have been that difficult to remove, and if damaged in the process I suspect the tumbler housing in the switch had something to do with it. Don't believe I would take the chance and insert the new tumbler in the old switch, may find you are face with the same problem before replacing, if recall they run less than $20. There is a pin on the tumbler that inserts into a slot in the switch housing, can only go in 1 way, thus the need to put the tumbler in the full counterclock position to remove or install. If either are damaged in any way then it will be difficult to remove in the future, and likely not work as it should, , may save the cost of another tumbler assembly in the future. Anyhow, had an urge to chime in and add my .
That annoying door chime is finally quiet! Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 130 07-21-2015 10:54 AM
Re-keyed my door locks How-to write up Duckmang 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-20-2014 04:15 PM
Ignition Switch / Tumbler mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 12-23-2012 08:33 PM
Ignition Key Tumbler Problem 2009 Convert 1987 - 1996 F150 & Larger F-Series Trucks 5 04-29-2009 12:09 PM
Removing Ignition Switch ? Bill W 1961 - 1966 F-100 & Larger F-Series Trucks 7 04-07-2007 12:41 PM
Tags
1962, 1963, 62, 66, assemby, atv, f100, ford, ignition, key, pop, removal, remove, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
