Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-14-2009, 01:10 PM
woodstockaz woodstockaz is offline
woodstockaz is starting off with a positive reputation.
3/4 of a tank so far and WON'T START. Lots of white smoke.
I've gone throught 3/4 of a tank so far of Biodiesel and this AM my truck won't start. It blows lots of white smoke through exhaust.
I'd normally assume that my fuel filter is clogged with the biodielse thing, BUT last night my electrical started acting a little funny and I'm wondering it it might be a battery issue.
SO MY QUESTION is should you be kind enough to answer; White smoke..? Common for clogged fuel filter in a 7.3L Diesel just switched to Biodiesel?
  #2 (permalink)
Old 08-14-2009, 09:18 PM
amish77's Avatar
amish77 amish77 is offline
amish77 is starting off with a positive reputation.
No it's common for an engine burning water. Though I guess burning is not an accurate term. The water flashes to steam in the combustion chamber, and then the steam flows out with the exhaust. This leaves me with four guesses.
1.) The head/block is cracked, letting coolent into the intake.
2.) The head gasket is blown, letting coolent into the intake.
3.) If the turbos are water cooled, then one of them can be blown, letting coolent into the intake.
4.) There is water in your biodiesel.
Of the four I think that the fourth is most likely, as that's what you recently changed.
__________________
300 CI bored .030 over with a 240 head (303 CI). Clifford valves, Comp Roller Rockers, crane cam, Offy intake, true dual headers, x-pipe, pretty spicy.
  #3 (permalink)
Old 08-15-2009, 09:41 AM
Rushmore X Rushmore X is offline
Rushmore X is starting off with a positive reputation.
Drain your fuel bowl and do a "crackle test" on the fuel. That will tell you in a hurry if there is water in there... (this was a hint from Fabman, can't take the credit)
I had problems with water in the fuel also until I was talked into dry wash w/ Magnesol. 9 batches since w/o any water issues.
__________________
2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, more to follow! Gone BIO!!!
  #4 (permalink)
Old 08-15-2009, 11:43 AM
CAn you elaborate on the "crackle test"?
  #5 (permalink)
Old 08-15-2009, 11:50 AM
Sorry, put a small ammount in a pan and heat to over the boiling point of water, say 250 or so. any water suspended will crackle and splatter out. (don't have your face over it)
__________________
  #6 (permalink)
Old 08-15-2009, 04:51 PM
...so....heat my fuel on the stove until I hear and or see the water vaporize but make sure....I'm assuming....that I don't hit the 400-500 degree mark where diesel ignites???
  #7 (permalink)
Old 08-16-2009, 02:29 PM
I just use an empty tin can with just an inch or so of bio in the bottom of it and heat it up outside with a torch slowly until it starts to boil and if it ignites no big deal. If there's any water in there it will crackle and splatter.
__________________
  #8 (permalink)
Old 08-18-2009, 07:50 AM
kirkharrod kirkharrod is offline
kirkharrod is starting off with a positive reputation.
I think the hot pan test is more accurate if you get the pan hot, and THEN put the bio or veg oil in the pan. Look for bubbles also, not just the crackle sound.
__________________
2002 F-250 Super Cab, 225,000 miles, 25,000 on WVO; Greasecar conversion, 140 gal grease tank, 30 plate heat exchanger, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, CAT ELC, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. ZERO grease related problems.
Tags
biodiesel , crane , diesel , exhaust , smoke , smokes , start , white , wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
