Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 09-16-2009, 10:10 AM
jimandmandy jimandmandy is offline
jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE. jimandmandy has a good reputation on FTE.
Looking carefully at that Toyota TSB allowing 5W-20 is for 2006 model year and later only. Our Toyotas are 1999 and 2005. I'm not going to take a 200,000 mile 1999 Camry and experiment with 5W-20 to gain 1mpg, maybe.
My experience has been that valve guides generally wear out before rings anyway. We did have one case where rings were not sealing well on a motorcycle and thicker oil helped raise compression and power. Smoke was not an issue before or after. Consumption was difficult to measure because we change the oil every race weekend.
One of the additives in modern "Energy Conserving" oil is a friction modifier that helps the oil rings scrape oil away more easily, leading to slightly less hydrodynamic drag.
Jim
  #17 (permalink)
Old 09-17-2009, 09:57 AM
fraso fraso is offline
fraso is starting off with a positive reputation.
The last link (BITOG: Toyota TSB On Oil Use) I posted was just to show that 440Magnum's general experiences with thick vs thin oils, which happened to be in a Toyota TSB discussion. I think he just prefers to use the OEM-recommended (hot) viscosities rather than unnecessarily thick oils (TX Heat and Oil).
Going back to the original question, see also Mobil One 15w50 or rotellaT 5w40. Incidentally, it looks like 440Magnum would recommend a 5W-40 (like Rotella T Synthetic 5W-40) for heavy duty use. See 1980 Dodge Van/Bus oil reccomendation).
As for Friction Modifiers, rather than affecting hydrodynamic drag, my understanding is that these additives bond to bearing surfaces to reduce friction:
Automotive lubricants reference book: Friction Modifiers
Lubricants and special fluids: Friction Modifiers
  #18 (permalink)
Old 10-20-2009, 11:49 AM
98explorerltd 98explorerltd is offline
98explorerltd is starting off with a positive reputation.
Recently I saw a TSB from Ford from 2002 (!!) that says that if your engine called for 5W-30, it is ok to, and you should, use 5W-20...
02-1-9***ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
Well ever since i've had my Ex, i've used Mobil 1 5W-30... at 155k, burning about 1 qt every 5k, but with no leaks, i don't see any reason to change...
any thoughts?
  #19 (permalink)
Old 10-20-2009, 12:04 PM
mprice mprice is offline
mprice is starting off with a positive reputation.
any thoughts?
I've run 5w20 exclusively in my Tritons and Vulcans and have had nothing but good UOAs, even at 12k miles on Pennzoil Platinum 5w20. I see no reason to change AND I see no reason not to change. I hope that helps .
  #20 (permalink)
Old 10-20-2009, 12:35 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
any thoughts?
Stick with what your doing... My warrenty is expired I'm running 5w-30 now.(from 5w-20)
__________________
FS: Factory Tech Valve Body for 4R100 http://www.ford-trucks.com/classifie...ct/27799/cat/5
69,873,761 firearms owners killed no one yesterday....
  #21 (permalink)
Old 10-22-2009, 09:20 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Did you ever decide on an oil? I'd say, if you feel the need to go 40 weight, go 5W-40, like Rotella-T Synthetic. Been great for me. Gives me the 40 weight that I want without the thicker viscosity at start up.
__________________
1986 F-150 5.0 EFI XLT Lariat 4x4
NP435/NP208/9" 3.50
"Custom Exhaust" and leaf spring overloads
31x10.50 15" Nothing special, but it's a damn good truck.
  #22 (permalink)
Old 11-01-2009, 07:14 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
[quote=6CylBill;7826763]Hey guys and galls
I need some thoughts. I don't know much about oil. I use 10w30 weight. My motor has a lot of miles and I was thinking about moving up to a heavier weight oil. My motor doesn't leak or burn any oil between changes, but is this a good reason not to change oil weight?
Is 10w40 the next step up? If so, is it enough to matter?
I don't want to strain my oil pump or anything like that but I would like to help prolong my engine life if possible.
Any information is good information. I've asked about this before but never really came to any conclusions. I'm ready to change oil weight now though.
Thanks guys
Bill, your 300 I-6 was built to last and to challenge the test of time. Do nothing different from the what the owners manual recommends and you'll be good to go.
I'm sure that part of your concern is that you moved into a colder climate and your rig is getting a little long in the tooth. Worry not my friend, you have obviously been doing all the right things right.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
Tags
10w , 10w30 , 10w40 , 30 , 40 , 400 , 99 , difference , engine , f150 , ford , motorcraft , oil , rotella , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
