Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-13-2009, 04:38 PM
jdm5630 jdm5630 is offline
Garage is empty, add now
jdm5630 is starting off with a positive reputation.
Keyless Entry Code
When i bought the expedition it didnt come with a manual or the card that has the code on it. Is it somewhere hidden on the vehicle? I know the older models have it uder the dash. Is it the same for 07?
  #2 (permalink)
Old 08-13-2009, 09:59 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
Nope not hidden on 07+. Have to go to the dealership.
__________________
2007 Expedition Limited White Sand
  #3 (permalink)
Old 08-13-2009, 10:10 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
you sure tikt b8?
where is the lock module? they've been putting that code on the module since 2003.
I'm at work now, but I'll try to dig though my Repair Manual when I get home. Send me a PM to remind me though if you can.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 08-14-2009, 10:32 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
TIKT is right, no codes like the old days. The dealer can retrieve it via computer.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #5 (permalink)
Old 09-30-2010, 07:30 AM
vipersinu2's Avatar
vipersinu2 vipersinu2 is offline
vipersinu2 is starting off with a positive reputation.
2010 expedition 5 digit keyless entry code
2010 expedition 5 digit keyless entry code location. It is located on the (SJB) smart junction box, Passanger side fuse box, remove the plastic panals and look on the rear of the fuse box you will see a sticker with the code. No tools Required!
[IMG]Click the image to open in full size.[/IMG]
  #6 (permalink)
Old 09-30-2010, 10:54 AM
berry1234's Avatar
Ahhh! Nice. Is the fuse box attached to the body?
__________________
  #7 (permalink)
Old 09-30-2010, 11:12 AM
vipersinu2's Avatar
Quote:
I just removed the passenger plastic rocker panel, then part of the weather stripping, then pull on the passenger side kick panel it will come right off, you will see the SJB and the sticker, I took my pocket knife to start prying the sticker off once started just pull it off there is plenty of room, this project will probably take you all of 15 minutes.
  #8 (permalink)
Old 09-30-2010, 11:23 AM
berry1234's Avatar
And you have tried the code to make sure it is the door code?
__________________
  #9 (permalink)
Old 09-30-2010, 12:50 PM
vipersinu2's Avatar
working perfectly!
  #10 (permalink)
Old 09-30-2010, 01:05 PM
berry1234's Avatar
Nice find. Great Job.
__________________
  #11 (permalink)
Old 09-30-2010, 05:08 PM
great find. I am going to go find mine just because I know it is there now.
__________________
  #12 (permalink)
Old 09-30-2010, 10:03 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
I think this qualifies as breaking news! Thanks!
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #13 (permalink)
Old 01-04-2011, 08:35 PM
RyanJan RyanJan is offline
RyanJan is starting off with a positive reputation.
Tremendous tip!!! Thanks a million...
I just bought an 08 Expedition as primary vehicle for my wife to drive.
Did not think to check when I bought it, but the keyless entry card was missing and nothing written in the manual.
I tried to call ford to get the code with my vin number and they waned me to go to dealer who wanted to charge me 60 bucks to get the code out of the computer.
I was going to take it to the dealer, but before I got a chance by wife locked the keys in the car. To make matters worse, my son was strapped in the car seat.
The next day, my brother in law found this for me.
Worked like a charm.
  #14 (permalink)
Old 03-31-2011, 09:47 AM
SickPup404 SickPup404 is offline
SickPup404 is starting off with a positive reputation.
I just had to sign up and post a big "Thank you" here!
We bought a 2007 Expedition EL Limited a little over a year ago and it had no "glove box goodies". No manuals, no key code card, and only 2 keys (no fobs).
I've been searching through a lot of wires under the dash with no luck. However, I ran across Viperinu2's post with pics and found our code! The location of the SJB is the same as pictured on ours, however the label was different and the 5-digit code was pretty well smack in the middle with barcodes above and below it.
  #15 (permalink)
Old 04-07-2011, 08:57 PM
does this work on a 07?
Tags
04, 08, 2004, 2007, code, codes, entry, expedition, f150, f350, ford, fords, keyless, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
