1993 F-150 wiper problem, not working. - Ford Truck Enthusiasts Forums
Old 08-13-2009, 03:48 PM
anoxic anoxic is offline
anoxic is starting off with a positive reputation.
I have a 1993 F150 XL 4.9 the wipers died. Since I purchased the truck 4 years ago the wipers never worked well. Unit is a two plug with washer.
No current to either connectors. Wiper brain behind glove box looks good when removed and opened. It does click. The no.2 in the fuse box now gets hot, the wiper motor when running did as well. I assume no.2 is the relay? I tried to remove but will not pull out. I removed the two screws to remove fuse board, the screw brackets will not allow the boards to be removed. How do I remove what I think is the relay to test and or replace?
Old 08-14-2009, 07:44 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
If the wiper motor was hot then I would think it is faulty and maybe pulled something else down. Hopefully some of the experts will reply soon.
Wipers Not Working WorldCommander 1968-2013 Full Size Vans 23 04-16-2016 07:13 AM
wiper motor wiring - EVTM? MustangGT221 1987 - 1996 F150 & Larger F-Series Trucks 5 10-26-2015 06:51 PM
wiper woes?? FIXED!! phatpharm85 1987 - 1996 F150 & Larger F-Series Trucks 7 08-09-2015 03:30 PM
Stumped.. Signals and wipers JPD Motorsports 1987 - 1996 F150 & Larger F-Series Trucks 3 01-07-2015 07:06 PM
Wipers only work on low, won't shut off 1994 f150 4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 09-05-2013 02:55 PM
Tags
1987, 1996, 2002, 93, dont, f150, ford, fuse, relay, remove, series, wiper, wipers, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
