Another wheel thread (center-bore and backspacing))
I've been looking around for while on this site and found most people running wheels on their vans use ranger/exploder wheels and seem to have no issues. But I have never heard mentioned the center bore gap. I mocked up a set of 15x6 wagon wheels the other day that my dad said I could have if the Aero wheels would fit his trailer, but the space around the hub has me worried. Pics below:
Would hubcentric rings be necessary? I love the way these fit, and I would still like to stay somewhat narrow for mileage.
What would the proper dimensions be for a 15x7 and what size tire to stay the same height and bring out to the very edge of the fender/bumper line?
It looks like I won't be getting these exact wheels b/c the centerbore on the Aero wheels won't fit over the trailer hub...but the questions still stand.
At least one of the Explorer wheels have deeply chamfered (or counter-sunk) holes that match the lug nuts with almost spherical shoulders. Once you cinch down those nuts into the holes in the wheel, they will automatically center the wheel, spacer ring or no. Just make sure that when you salvage the wheels from the Explorer, take the nuts as well.
As for keeping the diameter the same as stock, the largest tire installed on the Aerostar from the factory was 215/75/14. You can go with a 215/70/15 or 225/65/15 o a 15x7 wheel, and probably not have any problems with them rubbing on any fender parts.
I'm running 16" wheels from a '94 Mustang on mine. The Mustang hub bore is larger that the Aerostar, so it doesn't center on the hub. As long as you draw up the lug nuts properly, it'll be centered regardless.
The wheels aren't really hubcentric anyway - it's more of a guiding feature to help with installing the wheel. It isn't real practical from a manufacturing standpoint to make both the lugs and the hub act as centering features. The tolerances required to keep them truly concentric on both parts would very tight and cost prohibitive.
If the wheel actually used the hub for centering, chances are that the lug nuts would have a flat shoulder instead of a taper. My father's F-250 is that way. Incidentally, any Explorer I've worked on (4 different ones, all pre-'02) have had normal conical lug seats on all wheels.
snook715
413
11-02-2015 05:36 PM
19mfn96
03-15-2012 08:51 PM
Sunline Fan
12-28-2011 12:18 AM
denverslim
16
02-09-2011 01:40 PM
