Oil shooting out of the weep hole on number 4 Injector
Just changed all my injector O-rings. Fired it up before replacing valve covers and noticed number for injector was shooting a shot of oil out of the weep hole every time it fires. But no oil coming out of the discharge side. I’m wondering if I need to replace the injector? I need help I’m open.
Yes, weep hole.
On the square body (the top) of the injector, opposite of connector side is a small hole half way down the square body. That is where oil spurts out each time injectors fires. If you have not actually had the injectors out and in your hand you might not be aware of this hole. If I had not saw the oil shooting out I would not know of this hole.
Here's an old thread that sounds familiar:
https://www.ford-trucks.com/forums/1...hole-leak.html
Is this the weep hole?
whitetmw
03-18-2015 10:02 PM
meccox
12-19-2011 05:52 AM
