Go Back   Ford Truck Enthusiasts Forums > Misc. > Paint and Bodywork
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Paint and Bodywork SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-13-2009, 06:02 AM
needhelp49 needhelp49 is offline
needhelp49 is starting off with a positive reputation.
how much paint
do i need. im painting a 49 cab,doors,hood and the bed. one color and the fenders,running boards another how much paint will i need. to do the job I'm thinking 1 gallon of clear should do but how much base.
oh and i,m going to tint the sealer body color.
__________________
1949 f1
2002 f250
2007 mustang
2001 ranger retta
  #2 (permalink)
Old 08-13-2009, 07:22 PM
sgtrwg's Avatar
sgtrwg sgtrwg is offline
sgtrwg is starting off with a positive reputation.
I'm thinking of doing the same thing with my 53 F250, still in the cutting out the old and rotten replace with new and solid part but paint time is getting closer all of the time.
__________________
53 F-250
9N
1978 F-150 Custom
  #3 (permalink)
Old 08-13-2009, 11:01 PM
tinman52 tinman52 is offline
tinman52 is starting off with a positive reputation.
Need more info....are you painting inside of cab and bed? Under hood? What color? Some cover better than others..... what brand and mix ratio? what type gun.......hvlp? These are all factors.......T/M
  #4 (permalink)
Old 08-14-2009, 12:14 AM
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.
Like tinman said, need more info. I sprayed that wonderful Chevy gold color a few years back and it sprayed like water. It took 6 coats to cover. The guy wanted cheap, so we tried Keystones paint. After that, just for the sake of trying another brand, we got a pint of PPG. Sprayed a fender after preping it the same as the truck and it took the normal 3 coats.
If you use the old style guns (where the cup is on the bottom) you cant use all the paint in the gun.
Definatly need to know what all is being painted.
If you are going to be clearing the inside of everything, you might need a gallon and a quart of clear. Again that is gonne be determined by manuf and the look you are going for (show quality or everyday truck usage quality)
__________________
2002 Ford F250 4x4 V10<-FORD's best kept secret.
1947 Ford 1 Ton
2001 Sport Trac (Wife's vehicle)
Powered by Ford, Fueled by Madness
Support America and capitalism....BUY A FORD!!!!
  #5 (permalink)
Old 08-14-2009, 09:12 PM
grumpy46's Avatar
grumpy46 grumpy46 is offline
grumpy46 is gaining momentum as a positive member of FTE. grumpy46 is gaining momentum as a positive member of FTE.
just painted my 56 with ppg. went with 3 coats. did the whole truck including inside the bed, door jambs, around inside back window, dash and doors and under the hood. used almost one and a half gallons mixed 1to1. 4 coats of clear used almost 2 gallons.
__________________
tom
everyday is a good day
  #6 (permalink)
Old 08-16-2009, 12:12 PM
painting outside of hood cab inside dash 4 in strip over windshild and jambs outside off box and tailgate one color. and the fenders running boards and two small front pieces another color. body color will be burgandy. fenders gun metal gray.
__________________
1949 f1
2002 f250
2007 mustang
2001 ranger retta
  #7 (permalink)
Old 08-16-2009, 06:34 PM
grumpy46's Avatar
1/2 gallon of each mixed 1 to 1 will probably do it.
__________________
tom
  #8 (permalink)
Old 08-16-2009, 11:10 PM
The mixing 1 to 1 is gonna depend on a few factors. Temp when you are spraying and the product you are using. Some products require a 1 to .25 or .5 ratio (paint to reducer). But to get the most out of your paint, I would also recommend using red oxide primer for the burgandy and gray primer for the gun metal gray. No need to pay extra for tinted primer, as these are standard primers.
Also one thing to remember with the gun metal grey (actually a couple) 1) you will need to work relativaly fast with this to prevent as much metallic from seperating out of the paint as you use it. 2) You always want to paint the body part layed out the same way as it would be mounted on the vehicle.
And depending on how much experiance you have painting, I would recomend 3 quarts of color for each. That way you will definatly have enough. Plus the shelf life of unmixed paint is a very lond time as long as the can is sealed good.
__________________
1947 Ford 1 Ton
  #9 (permalink)
Old 08-17-2009, 08:04 PM
ok thats what i'll get and thanks for the tip on metallics. is omni paint any good thats about all i can get without driveing 100 miles
__________________
1949 f1
2002 f250
2007 mustang
2001 ranger retta
  #10 (permalink)
Old 08-17-2009, 09:43 PM
Omni is a brand from PPG. Its a cheaper line. Its okay. Deltron is the better base from PPG.
__________________
1947 Ford 1 Ton
  #11 (permalink)
Old 08-17-2009, 10:44 PM
ya it sucks local auto parts store used to carry paint. but thay sold out to oreillys now thay dont. nearest place is 30 miles away
__________________
1949 f1
2002 f250
2007 mustang
2001 ranger retta
  #12 (permalink)
Old 08-17-2009, 11:45 PM
I've had problems with Omni covering as well as "good" paint. Seems to take twice as much......... which is why I don't use it very often. BTW, 3 quarts usually is the same price as a gallon, at least around here, so you might as well get a gallon....good luck. T/M
Tags
cab , f1 , f150 , f250 , ford , gallong , gallons , how , needed , omni , paint , painting , tailgate , ton , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
