Anyone have LED Bulbs???
Anyone ever swap out their stock Tail/Brake/Turn Signal bulbs and front Marker/Turn signal bulbs for those LED bulbs that fit the stock base? I even saw LED bulbs for the license plate lights.
Found a bunch from this place that seems to be an even swap...
www.superbrightleds.com
Ayone have an exprience doing this swap?
My tow truck has led turn signal bulbs. However it has a flasher relay for incandescent bulbs. This results in a quite rapid flash rate. One of these days I will replace the relay for one engineered for the LEDs. A LED retrofit is a good mod as the LEDs will last much longer and use a fraction of the power of the incandescent bulbs. The reduction of power consumption will be a plus should you ever need to use your emergency flashers on the side of the road. They will last much longer without draining the battery below starting power levels.
I'm replacing all my trucks halogen bulbs with LED bulbs with the exception of the headlights and fog lights, which I want to change to HID. I'm using this company for my bulbs. http://www.v-leds.com/
daverennie
1999 to 2016 Super Duty
25
04-12-2012 08:36 AM
