Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-13-2009, 12:06 AM
spdmpo's Avatar
spdmpo spdmpo is offline
2000 Ford F-350
spdmpo has a good reputation on FTE. spdmpo has a good reputation on FTE.
Riffraff Diesel Performance FRx installed
Not sure if Clay wanted me to post this, but here's some highlights of his new FRx (aka CCK) he installed on my truck at RRE. We also installed a hard HPX line at the same time. It was a pretty noticeable difference after all the air was worked out. A smoother idle and quieter too.
Pics taken at night, hopefully they show the detail.
Remove FPR on the side of the fuel bowl and the return fuel line connected to it.
Install new block with barbed fitting with the new screws provided. I didn't get a picture of this new block, but it should be noted it is machined inside to act as a shimmed FPR. A very nice touch and does two mods at the same time here.
Remove the two bolts in front of the reservoir that secure the fuel bowl. No need to remove them completely, just pull them out until the bowl moves freely.
This is the reason you remove the fuel bowl bolts. You need it a little loose to rethread the hard line back on to the new block you just installed. It makes it much easier, otherwise you'll be fighting it. Ask Clay. After you get the return line threaded back on, reinstall the bolts to the fuel bowl and tighten. Then tighten the return line on to the new block.
Remove the fuel plug from the rear of the driver's side head and install the supplied fitting.
Do the same for the front fuel plug on the passenger side head.
It was getting late and didn't get shots of the 90 barbs that go on the fittings you just screwed into the fuel rails. But you screw those on, tighten, and slip on the fuel line on both fittings and run the line toward the fuel bowl.
Then take the machined "T" and attach both fuel lines to the T. Then from the T another short piece to the new block that was secured on to the fuel bowl.
And it will look like this:
It really was that simple. There are no factory lines to cut, no removing of the front accessory bracket and it all looks great. He really made some nice improvements to the other kits I've seen, like I mentioned about not removing the front accessory bracket, no cutting of the lines, and the machined in shim for the FPR. I'm really happy with how this one turned out on my truck.
The terminology I used is probably off, so what I wasn't sure about I made up, I can't remember what he called each piece.
__________________
Keith
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
'00 F350 CC LB 4x4 PSD - DP Live Tuning, ATS housing, 6.0 IC, Ford AIS, 4" Magnaflow, BD X-Monitor, Front leveling kit, Firestone air bags, JWVB, FRx, HPX, coolant filter, Hutch mod, ITP in-tank, Carter lift pump, CCV, Tru-cool, AIH delete, OBA, cold a/c
  #2 (permalink)
Old 08-13-2009, 12:37 AM
jkidd_39's Avatar
jkidd_39 jkidd_39 is offline
jkidd_39 has a good reputation on FTE. jkidd_39 has a good reputation on FTE.
Looks great! I got the same kit sitting in the middle console waiting for install.
Hopefully I can put it on there faster than you guys did haha!
__________________
*Andrew*(and bff Owlie)
2002 F-350 CCLB 7.3 255,000 Miles
*** 5" Cannon, 6637, DB's HT Starter, Pete's Cover, EV2's, Zoodad, 6.0IC/TC, CCV Mod, BTS VB, Van Turbo/WW, Casserly 160cc SS, RDP HPX, DP Tuner, 2.5" Lvling Kit, 05 Harley Grill, Ceramic IH Uppipes, In-Tank mods*** Next-Homemade RR, Water Inj.
Destroyed by Ford Mechanics, Resurrected By FTE and Riffraff Performance
  #3 (permalink)
Old 08-13-2009, 12:38 AM
big poppa's Avatar
big poppa big poppa is offline
Monitoring The Vitals
2003 Ford F-250
big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of big poppa has much to be proud of
Well, I,m kicking myself in the butt that I didn't do this mod at RRE when you did yours, thats for sure..Reps to yaa Keith for the great writeup and pics, looks like i,m giving Clay a call when gets home. Would be interested since it acts as a fuel shim also, what kind of fuel pressure it allows.??
__________________
Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto, GTP38R BB Turbo, S-B intake With Pete's Armor, MBRP Duals, DP Tuner F-5, 3 Isspros Gauges In Pillar, JW-VB, OBA, Clay's AIH Delete, Clay's FRx (CCK), CCV, Zoodad And GPR LED Mod and some other goodies. 131,000 on the ticker. PAA#26 Roadside Help Network Riffraff Diesel Performance http://www.dieselorings.com/ http://www.guzzle7pt3.com/index.php
  #4 (permalink)
Old 08-13-2009, 12:47 AM
spdmpo's Avatar
2000 Ford F-350
Yeah, now that we know the tricks to it, it goes fast. Well that and Nick isn't there to take out the wrong plug.
Quote:
Apparently it's enough fuel pressure to kill an already weak fuel pump. No seriously, that had nothing to do with it. Clay will have to advise how much it shims the pressure up, I really don't know.
__________________
Keith
  #5 (permalink)
Old 08-13-2009, 12:56 AM
big poppa's Avatar
2003 Ford F-250
Quote:
Interesting, I'll have to ask when I call him to order it. Not to get off base Keith, was the pump the culprit at the track that day, did you change it out at RRE?? I was running all around the campground and forgot to check in on that issue you were having..
__________________
  #6 (permalink)
Old 08-13-2009, 01:16 AM
spdmpo's Avatar
2000 Ford F-350
The issue at track day was just me being hypersensitive. There wasn't anything wrong other than the OBA I had that was bleeding some boost off.
The fuel pump had already been replaced by then. It was just it's time and was going to go I guess, I got lucky and it happened at the campground. Could have just as easily happened on the I-81 and left me stranded.
I hadn't even revved the engine up faster than an idle when it went out, it sat there and idled for about 3-4 minutes and died as I was leaving the camp site.
__________________
Keith
  #7 (permalink)
Old 08-13-2009, 01:21 AM
megawatt00's Avatar
megawatt00 megawatt00 is online now
megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future megawatt00 has a brilliant future
Great write up and pics Keith. They will be a great help to anyone that is considering doing this mod.
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER
http://www.roadsidehelpnetwork.info/
PAA # 14
RIP Mark.. I'll never forget you!!
  #8 (permalink)
Old 08-13-2009, 01:29 AM
big poppa's Avatar
2003 Ford F-250
Gotya, now I remember, the black tape mod..thanks for the explaination.
__________________
  #9 (permalink)
Old 08-13-2009, 08:16 AM
03_PSD's Avatar
03_PSD 03_PSD is offline
Black Smoke
2003 Ford F-250
03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE.
Clay's putting out some amazing products! Great post Keith!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
  #10 (permalink)
Old 08-13-2009, 01:17 PM
duck fan's Avatar
duck fan duck fan is offline
Remember 4WD
duck fan has a good reputation on FTE. duck fan has a good reputation on FTE. duck fan has a good reputation on FTE.
I was involved in the install on Keith's truck and can say that Riffraff has taken a popular mod (that should have been done by International in the first place) and made it easier to install and it performs as well if not better.
I can also tell you that the price is fantastic. When Clay gets back to the shop hes going to be busy.
__________________
Peter - NHRDA# 5078 - Member of the 200K+ club
2000 Excursion 7.3 - 6637 w/ Pete's cover, van turbo w/ ceramic coated exhaust housing, ceramic coated exhaust manifolds, WW, DP tuner, Warn hubs, gauges, foil delete, 6.0 IC, powdercoated IC pipes and spider, MBRP 4" turbo back, IH up-pipes, RDP AIH delete, OBA, RDP IC boots, RDP CCV kit
  #11 (permalink)
Old 08-13-2009, 06:18 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Good job Keith, Rep trolls have me now, but I'll get you some soon. Saving this link for the near future.
  #12 (permalink)
Old 08-13-2009, 07:32 PM
maevans's Avatar
maevans maevans is online now
<--Michigan GTG
maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE. maevans has a great reputation on FTE.
So the FRX mod will give you - " A smoother idle and quieter too" ??? this is the first time i have seen this mod.
Thanks Keith for the nice write up with pic's Rep's sent.
__________________
MARK
EARLY 99 PSD.
MICHIGAN CHAPTER
ROADSIDE HELP MEMBER
Pics and Mods in Gallery.
Have a Great day........
  #13 (permalink)
Old 08-13-2009, 07:43 PM
spdmpo's Avatar
2000 Ford F-350
Yep, it sure did. Everyone around even commented on it.
Thanks for the reps guys.
__________________
Keith
  #14 (permalink)
Old 08-13-2009, 08:12 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
The main reason we created this product was to make the installation more simplistic and do away with the compression fittings.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #15 (permalink)
Platinum Sponsor
__________________
Clay
Tags
2004 , 60 , ac , database , diesel , filter , ford , frx , intake , kit , lancaster , pa , password , performance , raff , riff , riffraff , spec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
