Question on Avanceing an Aftermarket Timing Set
Hi, I have n Edlebrock Timing set for my 79 351W with the stock cam. I was wondering how I install it to advance the cam. I know that you put it in the advanced keyway but it seems that doing this would still have the set installed straight up, just using the advanced keyway. So I guess I'm asking, do you have to turn the cam or crank, or is just using the different keyway what advances it? Sorry for the Dumb question but for some reason I'm baffled by this.
Josh
Josh
Hmm. I guess its confusing because when I put the set on and the crank sprocket on the keyway it seems that the only thing i've done is change keyways and not actually changed the timing. So is the difference just very slight? It seems that the crank to camshaft relationship has not changed at all. I don;t know if that even makes any sense. I promise I'm not dim and I'm sorry if Im over complicating this.
Thanks again,
Josh
Thanks again,
Josh
Use plasti-gauge to check the clearance between the valve & pistion after you do this. Some cam grinders leave as little as .001 of an inch clearance and if you adavance the cam without checking this befor firing the engine, it may not happen right away, but up to 1000 miles later on the engine as things begin to loosen up- you may not have enough clearance and the next thing you know is you have a valve that has gone through the piston!
RCrawler
24
04-20-2009 12:25 AM
200solomiles
01-12-2008 08:53 PM
Azguy54
08-21-2004 10:06 PM
William
10-28-2002 08:18 PM
