how can you guys turn the fuel up so much? - Ford Truck Enthusiasts Forums
Old 08-12-2009, 01:25 PM
84 f250 6.9's Avatar
84 f250 6.9 84 f250 6.9 is offline
84 f250 6.9 is starting off with a positive reputation.
ok I have heard of some guys cranking there fuel way up like 4.5 flats or as high as they will go without catastrophic results but then some of you say no absolutely not that it will burn it up if you turn it up that much.. what is a safe zone for doing this to a bone stock straight piped soup bowl deleted 6.9 ? I would like to stay aound my 20 mpg zone to
Old 08-12-2009, 01:43 PM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Bottoming out the fuel screw can damage the injector pump, but some like me are able to get away with it. I know mine is pretty worn out, so maybe thats why I can do that.
For the sake of the engine, its not a good idea to over fuel like that. "Rolling coal" will actually make it possible for raw fuel to reach the cylinder walls and rings. More carbon soot will also contaminate the engine oil.
If you keep your foot out of it, then I guess you should be safe and get similar fuel economy, but at the end of the day, you are still dumping the same amount of fuel into the engine.
Old 08-12-2009, 02:31 PM
all good points .. will I get a lil more get up and go if I turn it up .5 -1 flats?
Old 08-12-2009, 02:40 PM
joe f350 joe f350 is offline
joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.joe f350 has a good reputation on FTE.
maybe do u have a ram air if u dont that might still be to much fuel
Old 08-12-2009, 03:33 PM
David85's Avatar
Quote:
Generally diesels will make more power the more fuel you dump into them even if much of it is turning to black smoke (enough fuel will stall them, but these fuel systems can't pump that much).
In terms of power, yes, you will get more power the more you turn up the fuel. But after you pass the black smoke thresh hold, the gains in power drop off and EGTs become an increasing problem.
Best you could hope for is to roll the coal as a brief boost of power when ever you needed it, but you couldn't use it to climb long hills because of rapid EGT rise.
I tired this when my truck was N/A and even bottomed out the screw once. The truck had much more sensitive power responce off idle, but I found myself afraid to go all the way to the floor because of all the smoke it would throw. Eventually turned it back down close to stock settings untill I found a turbo. Yes, it did hurt fuel economy, by about 2 MPG on average. Driving style might be able to compensate for that.
Old 08-12-2009, 03:39 PM
alright i think im def gonna mess around with it
Old 08-12-2009, 03:43 PM
be carefully and get a pryometer cause i dont want to here u melt ur piston in that perdy truck
Old 08-12-2009, 05:51 PM
alright so i took the triangle cover off i have my handy mirror and a light should this hex screw be visible like dead center of the opening? cuz so far i cant see it how do i get this screw visible?
Old 08-12-2009, 06:08 PM
Mat J Mat J is offline
Mat J is starting off with a positive reputation.
bump the engine over or turn it with a breaker bar, I THINK it needs to be around tdc but I cant remember.
If you invest in a good pyro it would be alot safer to drive. These pumps can put out enough fuel to melt pistons before turned up or so iv heard on here. Really you should atleast set up a ram air it is really cheap to do.
Old 08-12-2009, 06:20 PM
ill be doing the ram air thing .. i dont wanna get crazy with this fuel thing just a lil more
Old 08-12-2009, 06:39 PM
that good u dont want a big bowl of hot pistion soup
Old 08-13-2009, 11:15 AM
jedstamm jedstamm is offline
jedstamm is starting off with a positive reputation.
From my experience, turning up the pump does very little because you don't have a turbo. In the old mechanicals on truck engines, it was easy to get extra hp by turning up the mechanical pump and putting larger injectors and turbos on the engine. With no turbo, it makes it pretty hard to bump the hp on a diesel engine much. Most people that left their IDI's stock but wanted more power just decreased their tire size.
Old 08-13-2009, 11:37 AM
yeah i already gave up on it lol couldnt figure out how to get my tdc
Old 08-13-2009, 12:03 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
I had to rotate my engine with a breaker bar until the timing mark on the dampener was at the one o' clock postion(facing the front of the truck). You may have to do it twice. The screw is really hard to see, I actually turned my motor over 3 times before I realized it was further back in the pump than I thought. I used a small mirror and a single LED flashlight to see the dang thing. I turned my truck up 2 flats, it has a little more kick, EGT's were hardly affected(normal driving anyhow), and I only blow a little smoke under heavy acceleration. I blow a little more when pulling a load.
Old 08-13-2009, 12:48 PM
Here's the shade tree way to get to tdc. Take the glow plug out of cylinder 1. Put a piece of light weight plastic or something in it or on top of it. With a breaker bar, rotate the engine until the plastic gets blown off. Once the plastic blows off, line up the timing marks with the dampner pulley.
For finding the allen head on the screw, the easiest way is to find someone to rotate the engine with a breaker bar while you get up top with a flashlight and mirror. Once the allen head shows itself, have your buddy stop rotating the engine.
2wd 6.9 Diesel..how many of you have them? az3pqf Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 47 09-26-2016 09:21 PM
MY PICKUP DEMOLISHED by DRUNK DRIVER satx78247 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 50 09-23-2016 06:08 PM
7.3 IP in a 6.9. MPG tanked...suggestions? darryl97420 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-12-2015 11:12 PM
What do the zone #'s 1 -15 mean? Crazyotto1 1999 - 2003 7.3L Power Stroke Diesel 2 02-07-2014 03:34 AM
4.9L straight 6 stalling, backfiring, bucking jonothan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 12-31-2013 07:15 PM
Tags
69l, 73, 88, big, borg, diesel, ford, fuel, idi, screws, t19, trucks, turn, turnin, warner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
