Shakes when take off - Ford Truck Enthusiasts Forums
Old 08-12-2009, 05:36 AM
1992 F150's Avatar
1992 F150 1992 F150 is offline
1992 F150 is starting off with a positive reputation.
No matter how smooth I let the clutch out first gear shakes, kinda hard sometimes! It's only first though. U joints? I tried to move the drive shaft at the u joints when the truck was parked and left in gear and there was no movement. When I leave it in neutral it moves. Not sure what's wrong, any help would be great!
PS, whats it take to clean up the slop in the steering wheel?
Old 08-12-2009, 07:55 AM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
Cant help you on the shakiness but here... There is a whole thread we just got done with about loose steering.
http://www.ford-trucks.com/forums/87...-steering.html
Old 08-12-2009, 08:38 AM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
A weak pressure plate can cause a shuddering, only happens in first gear taking off and sometimes effecting reverse. Sometimes if reverse is low geared enough its not effected as bad if at all.
Old 08-12-2009, 09:03 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
A partially seized U-joint will cause this and won't be obviously loose. It's worth the effort to unbolt it and take it out for a closer inspection, just put a chalk mark on the shaft and axle yoke so it goes back in the exact same orientation.
Old 08-12-2009, 07:13 PM
1992 F150's Avatar
So I guess it'd be cheapest to see if it is the U joints first? There are 2 right? I'll use a Haynes manual to guide me so any pointers and tips would be great! Thanks,
Noah
Old 08-12-2009, 08:57 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
oldblu65 is starting off with a positive reputation.
Shaking ?
I have an old truck that I've owned for a number of years ! It used to be my daily driver but it got to where the engine didn't run very well and it had a terrible amount of chattering when you tried to pull out no matter how easy you tried to do so . I always figured it was the clutch or flywheel causing it . As time went on , it was relegated to the garage and I drove my car everyday. About two years ago , I thought it was time to revive that old truck . I bought a V8 to replace the old tired 6 cylinder . When I pulled it out , I was surprised to find the actual cause of the chattering ! The bell housing was missing two bolts and the rest were loose ! When the new engine went back in , with the correct amount of bolts tightened to the proper torque , the chattering was gone ! My be worth checking your bell housing just to be sure !
Old 08-13-2009, 10:44 AM
xpl0sive xpl0sive is offline
xpl0sive is starting off with a positive reputation.
my truck does this too, it feels like its coming from the rear end, so my guess was the u-joits. i ordered two new ones, havent got a chance to replace them yet... also, when i'm stopped at a light and go to take off, it feels like the drevveshaft spins a bit first, then it clicks on and taks off... it feels like a THUD and i dunno what's causing it... is my rear-end on the way out or what?
SUPER strange issue with '02 F-250.. Help? Nunez57 1999 to 2016 Super Duty 13 03-18-2014 01:35 PM
Shaking under load Blmorre 1987 - 1996 F150 & Larger F-Series Trucks 7 12-28-2012 01:37 PM
Shakes in forward, Fine in reverse daddy172005 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 09-05-2010 12:45 AM
shaking at high speeds 1984 f-250 Explorer, Sport Trac, Mountaineer & Aviator 4 05-25-2004 07:36 AM
What are the signs of bad u-joints? Bimmer ese 1987 - 1996 F150 & Larger F-Series Trucks 20 03-29-2004 08:25 AM
Tags
1990, 1994, 1st, car, f150, ford, gear, put, shake, shakes, shaking, starting, steering, taking, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
