Well I am in a power hunger adiction right now! I go thru this every year and spend some money, HA I want to learn more about this Hybrid Injector! I was told my stocker can be upgraded to the hybrid? I was thinking of going single shot but I guess the Hybrid gives better mpg and is just as good as the ss and might even flow more than the ss? anyways I just want to know more about the hybrids? any info anyone?thanks in advance!
__________________ Jeff
01' CC PSD LARIAT 4X4 6" Spring Superlift, 37's
Proud Member Of The Brotherhood
WW,RRP AIH delete,RRP HRX, DPTuner, ISSPRO EV2's, TCT Tranny, HH mods, DFA RR and CCK, CCV, Tymar w Pete's Cover, DB 200A, 6.0 Intercooler, AD in #8, 5" Cannon, RedHead SG,
You make one by taking the plunger and barrel assembly from a B-code injector and stick it in an A-code. What happens is the injection pressure ratio drops. This means that you can flow just about as much fuel as a B-code, but only use as much oil as an A-code to do it.
The other part of a hybrid setup is choosing your nozzle. If you stick with stock nozzles, you can tune a hybrid to run exactly like a stock injector. Increase the pulsewidth and/or ICP and you get more fuel. If you go with a larger nozzle, you can actually flow more fuel in the same amount of pulsewidth. However, to tune back down to a stock level of power, you have to cut back on pulsewidth. It can be done fairly easily by most tuners, but timing does get a bit tricky. The advantage of larger nozzles really hits home at higher RPM's, as you don't have as much time to inject fuel at faster engine speeds, so the larger nozzle helps to flow more fuel in a shorter amount of time.
Hybrids are a very versatile injector. They can flow large quantities of fuel, and do it with less oil than straight up B-codes. At the same time, they can be tamed with tuning to be very streetable, and are great for towing when matched with a proper turbo setup. For an all-around setup, hybrids are the way to go.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
Aw sheet, Curtis beat me to it. Oh well, his explanation is better
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2 God speed Markadeck, you will be missed ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
__________________ The Brotherhood of FTE <~click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody 2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
__________________
JR Strout..aim UNTAMND...2000 F350 4doorLB 4x4 PSD auto, F6, OBA, SS HPX, 4" exh, WW, underdash gauges, BLUE dash lights, AIH Delete, CCV to the rear, FORD apcm Idle controller, airaid w/modified airbox...LOTS and LOTS of tools in the back__parts not yet installed 08 rear cover Coolant filter 6liter transcooler external trans filter sonnex/springs
67 Mustang GTA Fastback 390dual-quad c6...not stock www.UNTAMND.com 91 Geo Metro TURBO 3cyl, large fmic, large turbo, tiny tires...and Yes, its fast!
Do NOT buy from them, unless you want a truck that runs like total crap.
They won't even give you the specs of their injector rebuilds. Without the specs, you can't tune correctly for them. Only a hack job shop would be like that to their customers.
Any quality shop will give you all specs on injector builds, plus provide you with flow matching and sheets to show the flow match.
__________________
Curtis
2002 F-250 PSD
Blaine if you are interested in looking into larger injectors, you can do like I did on a budget. I wouldnt quite recommend the DIY kits b/c you cannot bench flow test them, as well as check every part. I have a very good friend who works at a Diesel Injector shop that deals only with the HEUI injectors and I had him build mine on the side at the shop. I bought the nozzles separate and shipped them to him, he took a set of cores from the shop, went through everyone of them, replaced all wear parts, flowed and tested all injectors, and they have all the right equipment, as I mentioned these are the only type of injectors that they deal with. If you are looking into hybrids I thought I would throw this out there as an option, and as others have said, Curtis hit the nail on the head with a great explanation.
However, there is so much more that goes into it besides throwing in a set of hybrids. You are good to go with your motor since it has forged rods. Depending on what size of hybrids/nozzles you went with, there are alot of supporting mods that need to be addressed aswell, such as turbos, fuel system, big oil(depending on how large of hybrids), and not only the stuff for the motor, you have to think about the rest of the truck too, like a clutch if you have a manual, and alot stouter trans if you have an auto(as I mentioned, it depends on how big of hybrids). Along with a list of other things.
It also depends on what you plan to do with the truck, whether it be a daily driver, tow truck, weekend toy etc as to what size injectors/turbo/nozzles/....would best fit the intended purpose.
It all comes down to how much money you want to drop on it. And dont get me wrong you can do quite alot on a budget, it depends on how much you want to squeeze out of what you're running in it.
Hope this helps a little, I've been there before
Fep 9 I bought my truck, only had a pos banks chip, exh and intake
Apr 3 I had the motor tore down to the block rebuilding it for a lil extra hp lol
__________________
Cory
2002 F-250 supercab SB 4x4 Handshaker E.T.A.P.S. Co-founder
4" lift and 35's and its a slow turd
Quote:
Originally Posted by jdecker88
Can't is not in Cory's vocabulary he's like Chuck Norris with a wrench
Thanks Curtis for the info and heads up. Been talking to different members here that run them trying to learn more and its greatly appreciated. I,m definitly going for hybrids from a reputable builder as my next investment.. Reps to yaa..
Stay Stay STAY away from those jerks.. They are trash.. it only cost me about $4k in labor swapping out my injectors in Ford dealerships across the country to find out!
Thankfully Riffraff saved me and taught me how to R&R injectors!
__________________
*Andrew*(and bff Owlie)
2002 F-350 CCLB 7.3 258,000 Miles *** 5" Cannon, 6637, DB's HT Starter, Pete's Cover, EV2's, Zoodad, 6.0IC/TC, CCV Mod, BTS VB, Van Turbo/WW, Casserly 160cc SS, RDP HPX, DP Tuner, 2.5" Lvling Kit, 05 Harley Grill, Ceramic IH Uppipes, In-Tank mods*** Next-Homemade RR, Water Inj. Destroyed by Ford Mechanics, Resurrected By FTE and Riffraff Performance
I thought I remember someone here having a problem with Diesel Care and Performance, but I couldn't think of who it was. Now you've jogged my memory.
__________________
Curtis
2002 F-250 PSD
