I did what ya'll said but can not get my pic to upload. It is a flickr picture.
Go to flickr and right click the photo.
select copy image
come to this thread and click in
do this [img] right click and select paste
it should look something like this [img] www. whatever , this does not matter,but at the end of all this do this[/img]
your picture will show in your post when you submit it
This is my 81 Bronco. My grandpa bought this new in Alabama the year I was born. I towed it from there to my house here in Washington back in march. I ditched the t170 crap 4 speed and put a AOD in it. It also has a 470 truck avenger carb and a offenhauser intake. There is still lots of work to go but this is a start. Hope you don't mind if its a Bronco pic not a truck.
Matt
Reason: Adding stuff
I special ordered mine in 1985, I had to wait 3 long months before I got it. 460 C6 XL package 3.55 factory engine and trans oil coolers, purrs like a kitten @ 121 K. BTW, read the plate!
This is my 81 Bronco. I ditched the t170 crap 4 speed and put a AOD in it.
FWIW, I went through two AOD's in probably 40,000 miles in my Bronco when I put 33" tires on it. If you didn't Beef up that AOD or Lower the gearing in your Diffs you could be looking at trouble.
I plan to make it pretty. I want to put it back to perfect but not so nice I am afraid to drive it. I want to go efi and make it dependable enough to drive everyday. For now the AOD is stock. but a deep pan and 2000 stall will make it a little easier on the trans. I have run a AOD in a 70 cyclone with a 351 Cleveland that I ran hard and it held up but i had it built up. What kind of problems did you have with your AOD. It will help me fix things before it happens. I hope with the cooler temp here in Washington the heat won't be as much of a problem as it was when I lived in Texas.
