Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 08-12-2009, 12:40 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
That's a pretty crazy story,man talking about a run of bad luck.Glad to hear you're ok.
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
  #32 (permalink)
Old 08-12-2009, 09:07 PM
Thunderduckie's Avatar
Thunderduckie Thunderduckie is offline
Thunderduckie is starting off with a positive reputation.
[quote=CampD;7821286]
Quote:
Originally Posted by Thunderduckie View Post
Recently, I replaced the ball joints on my '03 F-250 4x4. I have always worked on my own vehicles, and thanks to this post by Dave http://www.ford-trucks.com/forums/35...ll-joints.html I was able to comfortably and easily complete the job. I took my truck to the local Firestone the next day (Saturday) and asked that they do an alignment, balance and rotate the tires, do an oil and lube job and inspect the truck. I told them that I was taking my family on a trip to Chicago (about 1500 miles round trip) and I wanted to make sure that the truck was roadworthy and safe.
This is the first problem (not bashing here) but replacing the ball joints you should have noticed the drag link (always inspect all front end parts when you replace one). Now on to the part about the chain stores, most responding posts are correct, these stores are manned by kids out of school and getting on the job training. Your correct a good mechanic would never had aligned the truck without checking it over first, 2nd the alignment rack would have alerted the mechanic to a problem.
Finialy, glad that you and your Family are ok.
You are absolutely correct. I should have checked the parts and found the problem myself. It was a dumb dumb move on my part after working a 12 hour shift and then doing the ball joints till midnight. The point of the post though is that I am not a trained, paid mechanic. It is their job to make sure that the truck was roadworthy and to perform the work in a timely and professional manner, which they did not. No offense taken BTW.
  #33 (permalink)
Old 08-12-2009, 09:49 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future F350-6 has a brilliant future
Good post and glad everything turned out well. I'll agree it's always a good idea to make sure the receipt matches what work should have been done, but I think the most important part of the story is that often times, your truck will give you signs something is wrong before complete failure.
If the slight vibration had occurred on a short trip to work, then it could have easily been put off till later. Then the gradual worsening, which would have been over days instead of miles, may not have been as noticeable, and that's where the bad stuff tends to happen.
If you think you notice something with your truck, that's the best time to check it out.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 310,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #34 (permalink)
Old 08-13-2009, 10:10 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
OP: Glad you're ok and things got fixed before a catastrophic failure.
Speaking of crooks, there are plenty in my area....
I went over to my neighbors house last night (has an '04 F250 6.0) and he started telling me about how his FICM module went out while he was out in the middle of nowhere. He had his truck towed to Tomball Ford where they fixed his truck for a nominal fee of $1200; after telling him his warranty ran out in April. They told him in order to replace the FICM, they had to remove the turbo, oil filter, fuel filter, intake, and a few other parts because the FICM was located in the valley of the engine and was "gear driven". When I showed him where the FICM was and that you only needed to remove the intake the get to it, well....
That's why a Ford dealer or any other mechanic will not touch my truck unless it's something I just can't do. Even then, that's what I have FTE for.
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #35 (permalink)
Old 10-22-2009, 01:01 PM
Flatinfifth Flatinfifth is offline
Flatinfifth is starting off with a positive reputation.
Trustworthy wrench
This thread is precisely what I needed to see. I own a 2002, 7.3 STOCK. It has 124000 miles and is just now needing pads..........I take care of my truck. Regular oil changes (I do them), etc. Second set of tires and shocks (next I get Bilstein...didn't like the Monroes). Well, the dreaded front end rattle issues have come into play and I need to rebuild the front end; bushings, ball joints, etc.
I don't have the time to do it myself and need to take it to a GOOD, HONEST mechanic that is experienced with Ford truck suspensions here in the L.A. / San Diego corridor. Does anyone out there know of such a creature????
Multiple thanks.
Flat
PS: My brother and I are on the sidelines, getting ready to buy an 09/10. Issues with these guys?? I'll never sell my 7.3....love that truck!!!!
  #36 (permalink)
Old 10-22-2009, 01:40 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
Quote:
I've had my truck and have been able to do all of the work myself. I'm so anal about it that I just bought some wheels and tires, and when they come in I'm taking them home and putting them on my truck myself!
As for mechanics, I don't know of any specific ones down here in San Diego. I'm sure there's some good ones in Santee (there are a lot of shops over there) but I haven't had any experience with them. As for dealerships, I drive out of my way to give El Cajon Ford my business. I've not put my truck in for service there, but everybody I've dealt with has been very nice and helpful (especially the parts guys ).
I know it's not much, but I hope this helps some.
EDIT: You might try calling these guys...Dion International Trucks, LLC. They are the fleet International truck parts and service guys for San Diego. They might be able to tell you who would do good work on your Super Duty.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #37 (permalink)
Old 10-22-2009, 11:03 PM
Mechanic
Brian 42,
Thanks for the quick response. I had taken my truck into Glendale Star Ford for this rattle issue for about a year and they told me there was nothing wrong. When I took it in this last time, they found EVERYTHING under the sun wrong with the suspension.......it has the appearance of HUNGER rather than honesty. Before when I took it in, they claimed it was tires out of balance.....the same tires???
At any rate thanks for the heads up on the people your way. I often fish in San Diego Bay from my kayak but I think it would be difficult to do the maintenance thing down there. I will contact your International people tomorrow and see what they have to say.
I find it so difficult to find an honest, knowledgeble and dedicated shop now days. Twenty years ago it seems people in So Cal were more honest. I am also real anal about my cars but in today's business climate I don't have the time.
How tough is it to replace the bushings and ball joints in the front end? Lots of cursing and swearing with bleeding knuckles?? Then once that's done, who aligns it??
I know..too many questions..Thanks again for your help. I appreciate it.
Flat
  #38 (permalink)
Old 10-23-2009, 02:21 AM
figurhead's Avatar
figurhead figurhead is offline
figurhead is starting off with a positive reputation.
Flatinfifth, I would call www.ocdieselshop.com. Bud is the owner and a master Ford diesel mechanic for over 20 years. He left Tuttleclick Ford (I think) a year ago or so and started his own shop. This guy in an incredible job on rebuilding my 6.0l. He gave me many options, let me choose which ones, and was honest as could be.
I would recommend him for anything. He knows ford SDs like no other; engine, suspensions, and all. At least he could give you a contact if you are too far away, since he is in South Orange County. If you call him, tell him Chris w/the large blue f350 says 'hello'. No kickbacks for me, I'm just helping out someone who really knows his stuff. His place has been slammed busy since the day he opened his shop. I actually got his name from the head of the ford-trucks OC chapter, and couldn't have been happier. Good luck.
OC Diesel Shop 23854 Via Fabricante Suite G-4, Mission Viejo, Ca 92691 Phone: (949) 297-8477 FOR ALL SD DIESEL ENGINE/TRANS/SUSPENSION/ANYTHING
P.S. www.DependableOffroad.com in Anahiem does a darn good job, and they are honest, too. They (Steve) built my truck originally, in 2003, (before I owned it) and everythng is still holding together perfectly. Not bad for how big it is. The quality of their work speaks for itself. Steve is the owner and has been doing this since we were kids, in 1978.
Dependable Offroad 1542 N. State College Blvd. - Anaheim, California 714.774.1471 FOR ALL AFTERMARKET 4X4 INFO AND PARTS
As for trusting mechanics, that's a difficult one. I do most everything myself. Never became a master mechanic, but had 4 years of HS/college auto-mechanics, and doing it for 20 years since. I have a few other mechanics I trust; but these two are the guys I trust on my truck. If it's too big for me, then they are where I go.
__________________
2003 F350 6.0L CC LB 3.73s (Daily Commute)
- 10.5" Donahoe Racing Springs / 39.5" IROKs / Dual Fox Shocks
- 4" Turbo Back SS Exhaust / ARP Headstuds / SS EGR Cooler
- Banks Intercooler-Intake / aFe Intake Filter
- Magnafine PS Filter / DieselSite Coolant Filter
- SCT X3 Custom Tunes from Eric @ Innovative
  #39 (permalink)
Old 10-23-2009, 06:56 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
Quote:
Originally Posted by Pinky Demon View Post
That's why you have to get in bed with a really good guy, that you personally like and trust. I've been taking my vehicles to the same guy for years and have always been extremely happy. Find yourself a good mechanic and stick with him.
+1 on that! And, if I couldn't find a good local mechanic, the dealer is the next best option if your willing to pay the price.
I'll bet that Firestone has lost a good customer.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
  #40 (permalink)
Old 10-23-2009, 10:15 AM
Mechanic
Man.............THANKS!!!! I'll be all over this next week.
What a forum!!!!!!!
Flat
  #41 (permalink)
Old 10-23-2009, 01:34 PM
brian42's Avatar
It took me two 8 hour days, but you can probably squeeze it into one. You might be able to do it quicker (I am slow and methodical for the most part), but you want some extra time set aside for any issues or complications. I also replaced all of my tie rods and drag links too.
I had mine aligned at my local Firestone.
One hint if you do the ball joints yourself: PB Blaster. I soaked all of the bolts and nuts I could get to the night before and morning of and had no issues removing anything for the job. Just my .02
__________________
THE MOOSE
  #42 (permalink)
Old 10-23-2009, 11:12 PM
dstig1 dstig1 is online now
dstig1 is gaining momentum as a positive member of FTE.
Quote:
Dude, no offense, but you live in So Cal. Things don't rust in So Cal. (BTDT) I hit everything with penetrating oil a few days before doing any suspension work, but if I didn't have a serious impact wrench, it really wouldn't matter...
Good adivce? Sure, but there are limits of where you live vs what results to expect.
__________________
- Dave
2005 F250 Lariat SuperCab Long Box 5.4 Auto 4x4
1999 Explorer AWD 5.0 4-door
  #43 (permalink)
Old 10-24-2009, 01:36 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Again, "OC Diesel Shop - Home of Bud" has the reputation here in SoCal among those in-the-know!
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #44 (permalink)
Old 10-25-2009, 08:27 PM
suzuki0702's Avatar
suzuki0702 suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
i need to put in my 2 pennies here. for 1 my father is a 23 year firestone veteran. hes the shop manager here at the kent firestone by kent state university. hes been at every firestone in northeast ohio, hes ASE certified in every category except body work, and is continually renewing his certifications. now i understand, its my dad.
Firestone is a corporation, they employ thousands of mechanics, obviously theres going to be some bad grapes. ive never had anyone other than firestone work on my truck. my dad does always put his "best" guy on it, but never the less, it wasnt firestone that screwed up your truck. it was the mechanic and he had hell to pay for what he did to your truck. it just seemed you had a hate for firestone. they do have honest firestones out there.
__________________
2004 F250 CrewCab, FX4 Off-road, 5.4, K&N FIPK, Jensen 7" TFT flipout touchscreen, Whelen Hideaway strobes, 1650 CCA dual batterys, 8' 6" western proplus
  #45 (permalink)
Old 10-29-2009, 09:33 AM
SD work in So Cal
Chris,
I have an appointment with Bud tomorrow Friday at 9 AM. Hope to get most of the intense stuff done by him. I really have the knowledge but no time; I remember when I did, but it seems like such a long time ago. I did order a set of Bilstein HD's from Shockwarehouse.com and I"ll probably install those myself as the job is pretty straightforward. BTW....if you guys have never used it, Kroil is one heck of a bolt/nut/rust removing penetrating oil. I have had a gallon for the past fifteen years and probably still have half the can. Great stuff.
At any rate, my initial contact with them was great and professional. Thanks for the referral. I'll tell Bud you send him your regards.
Thanks a million.
Flat
Tags
1978 , drag , f150 , f250 , ford , key , link , mechanic , mechanics , quits , roe , run , running , truck , trucking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
