Picture of a 302 with alt right/PS pump left - Ford Truck Enthusiasts Forums
Old 08-11-2009, 03:39 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Does anyone have a front view picture of a 289/302/351/400 engine with an alternator mounted on the passenger side and a power steering pump mounted on the driver's? I'm trying to fabricate brackets to use a GM one wire and a Chrysler power steering pump on an 85 302 with a V-belt system. Need some ideas.
Old 08-11-2009, 03:50 PM
Luddle's Avatar
Luddle Luddle is offline
Luddle is starting off with a positive reputation.
Here's the 302 out of my Mustang.
Dirty and big pictures.
Old 08-11-2009, 03:52 PM
Luddle's Avatar
Old 08-11-2009, 03:58 PM
That bracket coming off the water pump looks like what I may need. What year is your Mustang? Also, I wondered if I needed a dual grooved water pump pulley as this engine has only a single like your Mustang. The alternator was mounted on the driver's side when I got it but I have to add a PS pump for the Volare box and that has to go on that side so I have to move the alt to the other side...
Old 08-11-2009, 04:01 PM
Luddle's Avatar
The Mustang is a '65, but the engine is off a '70? Granada. Luckally when I got the car, that was all done.
Old 08-11-2009, 07:18 PM
tlb's Avatar
tlb tlb is offline
tlb is gaining momentum as a positive member of FTE.
My 302 looks just like Luddle,s. It is also a 1970 but not sure what it came off of.The pump on mine is off a 68 mustang i bought at a swap meet in Columbus. Paid $20.00 for the pump and all the brackets. It has the small filler tube but uses the same bracket. I also have the same GM alternator. I did have to buy a two groove pulley off ebay.
Terry
Old 08-12-2009, 10:27 AM
dawolverine's Avatar
dawolverine dawolverine is offline
dawolverine is starting off with a positive reputation.
Those are standard mounting positions for a 302. Brackets are often interchangeable with these between years (I have a '71 and for the p/s pump either a pre or post 70's pump fits fine). You can fab up your own alt brackets fairly easily if thats the way you want to go or you can get fairly cheap ones pretty easily.
Old 08-12-2009, 10:41 AM
merc546's Avatar
merc546 merc546 is offline
merc546 is starting off with a positive reputation.
Vern, I have a 351W with A/C. Water pump pulley has a one groove pulley and the crank has a three groove pulley. 1st groove is for P/S which runs over W/P, 2nd pulley goes to alt and third groove is for A/C which runs over crank, A/C adjuster and A/C pulley. It says I can't post attachment so I guess that means pictures but the first two are just like Luddle's picture
Chuck
Old 08-12-2009, 10:49 AM
tlb's Avatar
tlb tlb is offline
Vern,
I have an extra bracket that mounts fron the water pump to the power steering pump.
It looks like the same piece shown in the pics above. If you are interested i can send it to you.
Let me know if you are interested.
Terry
Old 08-12-2009, 02:36 PM
Terry,
I sent you a PM.
Vern
Old 08-12-2009, 05:15 PM
first today's Avatar
first today first today is offline
first today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant futurefirst today has a brilliant future
My truck d.d. is an 83 f-150 with 302. the brackets are as you describe and will use the newer style ps pump. The alt mounts lower on the motor. Sometimes it helps because of space in the engine compartment. I am not sure what you are driving. Maybe it will help. It will also let you run a newer a/c compressor. They do have these with non a/c also. It is v-belt and not serpentine.
The alt is on the passengers side.
The power steering is under the a/c on the drivers side.
Looking for power steering mount for flat 6 eberf 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 01-25-2017 11:02 PM
Need picture of 81 F150 302 power steering setup WilliamKG88 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-05-2015 08:39 AM
Picture of a power steering pump mounted on a 223? turnrjr 1948 - 1956 F1, F100 & Larger F-Series Trucks 72 11-06-2012 12:13 PM
351 water pump on 302 yzracer63 1978 - 1996 Big Bronco 4 02-16-2011 11:43 PM
302 H.O. With C4 ? hotrodder72 1967 - 1972 F-100 & Larger F-Series Trucks 13 03-05-2010 04:55 PM
Tags
302, ac, alt, alternator, brackets, ford, move, picture, pictures, power, pulley, pump, sbf, steering, truck, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
