Anyone have vacuum hose diagram? - Ford Truck Enthusiasts Forums
Old 08-11-2009, 02:32 PM
barnbridge's Avatar
barnbridge barnbridge is offline
barnbridge is gaining momentum as a positive member of FTE.
While installing my EGR blockoff plate I must have disconnected a vacuum hose. The gray hose comes from around the top of the heater blower near the pass side firewall now and is hanging near the vacuum reservoir. It has full vacuum. Also, my AC blows out of the defroster for about 30 seconds then it's normal. If you might know where this hose connects to or can direct me to a vacuum diagram I'd be thankful.
Old 08-11-2009, 04:35 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
It connects to one of the heater hoses just above the passenger side valve cover very close to the oil fill tube. I think it controls the hot coolant. There's a small black device mounted inline and it connects to the center of a small diaphragm.
Old 08-12-2009, 10:38 AM
barnbridge's Avatar
Thanks, that did the trick!
Old 08-18-2009, 02:33 PM
mark6x43 mark6x43 is offline
mark6x43 is starting off with a positive reputation.
Do you happen to have a picture of where the grey vacuum hose connects? I believe I have the same vacuum line just dangling free, and I have a hunch someone removed this heater hose valve from my truck before I bought it. The heater hose that runs above the passenger side valve cover has a simple connecting adapter where I think this valve might have once been. If so, what are the ramifications for not running one of these valves? Will I be okay just plugging the end of the grey vacuum hose?
Old 08-18-2009, 03:07 PM
Quote:
That's a good question(s). I think by NOT running the valve you'll have hot coolant running inside the heater core all the time which might affect the cooling capacity of the a/c during the summer months. I am purely speculating here. I'm sure it won't hurt anything to simply plug the vacuum hose. It might actually make the rest of your vacuum operated accy's operate correctly, especially if you have ESOF 4X4. I know it will allow the rest of your climate control system to operate correctly, i.e. the airbox, etc.
Old 08-18-2009, 10:08 PM
barnbridge's Avatar
Quote:
Before you told me where the gray line went I just plugged it but my AC still blew through the defroster for a little while. One I connected it everything works as it should.
Old 07-29-2014, 07:00 PM
priusklr priusklr is offline
priusklr is starting off with a positive reputation.
So here's the Problem. A poster asks for a Vacuum Hose Diagram. I HAVE CHERCKED THE POSTS AND NOT BEEN ABLE TO FIND IT. Does FORD have one? Does anyone have it and willing to share it? I have a 2000 Excursion and there is NOT a diagram on the engine cavity anywhere! I bought the truck new. It's a simple question. Does anyone have a Vacuum Hose routing diagram. My Lexus is available on-line for free. My boat is available for free on-line. My John-Deer tractor is available for free on-line. GET WITH IT FORD!!!
Old 07-29-2014, 07:09 PM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
Jeeze. What way to ask
Old 07-29-2014, 07:19 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
Ford has one its in the EVTM book.
Its not fords fault you dont know were to look
Old 07-29-2014, 07:23 PM
Sure it is cheezit. Just like someone putting gas in their diesel tank. Damn Ford. Why couldn't they make it where it burns both.
Old 10-02-2015, 01:29 PM
handyandy123 handyandy123 is offline
handyandy123 is new and has a neutral reputation at this point.
ok....so i need more info on the grey wire, because mine disintegrated and my vacuum pump I think stays on and keeps running my alternator hard. the voltage in my system keeps dropping when I put the ac on and it blows out the defroster. obviously my leak is the grey wire that broke apart in my hands, but i see it plugs into a boot of sorts...can i just buy vacuum line? 5/32? and run new from that boot to the vacuum pump? or is a special vacuum line part from ford?
Old 10-02-2015, 04:21 PM
I just went through this last weekend. This will get you close: The gray line tees off from the motor that runs the air inlet door (6,7,8 in that vacuum diagram for manual controls). If you have auto AC it's a bit different. My gray line had disintegrated. I used some small shrink tubing to repair it but be careful with heating that line as it gets soft very quickly.
Old 10-02-2015, 04:33 PM
Thank you!
Old 10-02-2015, 08:29 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
Sorry no Diagrams, but the grey line goes through the fire wall into a diagram lookin canister , this is under the passenger side dash. Good luck
Old 10-02-2015, 08:52 PM
Quote:
I attached a drawing of the diagram, so save it to your computer for later use.
EGR to EVP 4.9LOldFordTruck 1987 - 1996 F150 & Larger F-Series Trucks 7 12-22-2015 03:38 PM
vacuum hose diagram irish12671 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 11-08-2015 05:35 PM
1994 E150 4.9L Vacuum hose diagram. rwbrooks50 1968-2013 Full Size Vans 7 11-30-2014 11:59 PM
302 Vacuum Hose Diagram?? JoeTaco1 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 09-02-2010 09:36 PM
Vacuum Diagram JaySVX Excursion - King of SUVs 0 12-28-2008 01:38 PM
Tags
03, 2004, 99, ac, diagram, f150, f250, firewall, ford, gray, heater, hose, powerstroke, truck, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
