Body stripe edges curling
Had the same problem a few years back. Cutting the edgem works for stopping the peeling action. If you want to remove it use a blow dryer to heat the stripe as you pull it back. I removed mine in the winter, and it made it a lot easier to take off. The adhesieve that is used is really sticky. Goo B Gone also works, but takes a while, and a lot of scrubing, good luck, Levi
02 F150 4x4 5.4 V8, 3.55 limited slip, sport.
__________________
02 F150 4x4 5.4 V8, auto, 3.55 limited slip, sport, 17" wheels, cat back duals with NO MUFFLER...
