Traction Control - Ford Truck Enthusiasts Forums
Traction Control
Old 08-10-2009, 10:34 PM
pinestar pinestar is offline
pinestar is starting off with a positive reputation.
Traction Control
Does any one know if you can turn off the traction control. I live on a gravel road and it keeps comming when the road starts to get a little rough.
Old 08-10-2009, 10:48 PM
v_tach's Avatar
v_tach v_tach is offline
v_tach is starting off with a positive reputation.
Owner's manual?
Old 08-10-2009, 11:03 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Rtfm. :-x02
Old 08-11-2009, 05:41 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
little button with a truck icon and 2 squiggly lines under it.
press and hold for a few seconds. the dash will pop up with a light that looks just like it.
Old 08-11-2009, 12:50 PM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
hold the traction button for 10 seconds, icon will flash in the display
Old 08-11-2009, 02:10 PM
Whiteline's Avatar
Whiteline Whiteline is offline
Whiteline is starting off with a positive reputation.
As noted already, one push of the button turns off the traction control, holding it 10 seconds turns off the stability control.
I love driving my F150, but I find this feature annoying. I spend a lot of time on gravel roads and in muddy fields, it seems like I'm constantly turning this off. Nothing worse than having this system take over in a mud hole!
It freaks me out when I'm into a corner with loose gravel and the stability and traction control starts up. It distracts from the driving skills I've developed over years of driving on gravel and dirt roads.
Old 08-11-2009, 02:38 PM
same thing here, gets on my nerves. i know its there to help but still, there needs to be on "offroad" button or something so this system doesnt interfere.
Old 08-11-2009, 03:29 PM
Tylus's Avatar
hold up, you can turn off the RSC system?
I gotta try that tonight. My Expy acts like a drunk who has been kicked in the junk whenever I get frisky in the loose stuff
Old 08-11-2009, 03:56 PM
yes you can but it re-activates at 30mph. sucks, i know.
Old 08-11-2009, 04:19 PM
Whiteline's Avatar
Quote:
Agreed on the "offroad" button idea!!
Old 08-11-2009, 09:13 PM
Well, it can be done... the Raptor has a way to turn all of that crap off. I wonder if one could pull the right fuses and kill those systems? I hate the traction control and turn it off (hold down button 10 seconds) at every crank.
Old 08-11-2009, 11:56 PM
v_tach's Avatar
I remember when people hated anti-lock brakes.
Old 08-12-2009, 02:53 AM
Tylus's Avatar
Quote:
still do
Old 08-12-2009, 06:31 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
Originally Posted by tylus View Post
still do
+1
I hope you guys are using the traction control and RSC to help reduce your insurance premiums. Every little bit helps.
Tim
Old 08-12-2009, 08:48 AM
jwh2car's Avatar
jwh2car jwh2car is offline
jwh2car is starting off with a positive reputation.
Have you guys held the brakes and then gunned it to trick the TC? I did it once just to see if I could squeak the tires at all and it worked. Have yet to do it again. Pirellis too expensive but was curious.
Traction control dry/paved/summer roads nlfireblade 2009 - 2014 F150 8 07-07-2015 02:03 PM
2008 superduty ABS, wet road symbol and traction control turning on and off constantly Brom014 1999 to 2016 Super Duty 1 09-04-2014 04:51 AM
Holding the traction button down smokersteve 2009 - 2014 F150 11 02-15-2013 05:46 AM
Traction control disable Nickhaulass 1968-2013 Full Size Vans 1 05-01-2010 10:20 PM
Traction Control on Superduty ?? Aquik72 1999 to 2016 Super Duty 8 12-10-2009 10:33 AM
Tags
09, 150, 2005, 2006, 2009, 2010, add, button, control, disable, f150, ford, fx4, problem, series, traction, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
