inline 300 6 cyl split manifold, no power - Ford Truck Enthusiasts Forums
Old 08-10-2009, 02:50 PM
serczh1 serczh1 is offline
serczh1 is starting off with a positive reputation.
Ok, clutching at straws here.
Inline 300 6 cylinder, 1979 F250 4wd
Just R=R'd split manifold, (the bane of my life), new plugs, wires, cap/rotor.
Compression test was better than expected.
Starts good, idles good.
Can't get it over 45 mph in 4th, in fact it slows down.
When I let off the gas, it will give a small surge, but then dies out again.
It goes downhill ok.
I am wondering about timing?, Vacuum advance? Read that advance is taken care of by the ignition module?
My friend and companion for 28 years now.
Nobody knows Jack around here.
Any thoughts? Hep me please.
If I'm in the wrong part of the forum, please redirect me.
Old 08-10-2009, 03:16 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
Sounds like a carb issue to me... How's the choke?
On a side note, what part of Idaho are you in? I've got an Econoline sitting in my driveway with a 300 that's going to get hauled off to a junkyard sometime here soon if I can't find someone to give it a good home or is willing to take it for parts...
Old 08-10-2009, 03:18 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
What is you initial timing set to?
Where do you have the vacuum advanced hooked up?
It sounds like you need more advance. The module "retards" the timing only during starting to help the engine crank over easier. Once you let off the key to "run" the timing is whatever you set it to.
Josh
Old 08-10-2009, 08:13 PM
All in the timing !!!
Yahoo, I got it.
I was reading about setting the timing and I noticed that the vacuum line needs to be disconnected and plugged for setting the timing.
That totally changed everything. (It was like 5 degrees After TDC).
I was able to drive up Phantom Hill and actually had to slow down for the tourists ahead. Normally it's a crawl up.
Read the directions lol
BTW it's set 6 BTDC, now.
And I'm near Sun Valley, I would love to check out the econoline, but am getting tossed out of our trailer park by the new owners and haven't worked since November. So getting my vehicle dependable is top priority. I can live in the back of the truck till the snow gets deep. lol
Thanks for the info guys.
Chuck arppworks.blogspot.com
Old 08-10-2009, 08:38 PM
murph77's Avatar
murph77 murph77 is offline
murph77 is starting off with a positive reputation.
I can't figure out if this is a happy, or sad story.
Glad to hear the truck is running well.
Good luck!
Murph.
Old 08-10-2009, 09:10 PM
Hey, having a vehicle that i can stay in and fix myself is worth more than money in the bank.
Life is all about how you look at it.
Here's my view. arppworks.blogspot.com
Thanks y'all Chuck
Old 08-10-2009, 09:17 PM
Bullitt390's Avatar
Whatever you do don't sell the truck!
Hope things work out well for you.
Josh
Old 08-12-2009, 01:09 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
Glad that fixed it for you, but sorry to hear about the no job. I know how that goes.
At least you don't have to worry about emissions like we do here in Boise. Fortunately, the split manifold setup with the 1bbl, no smog pump, and no EGR valve actually passed on mine.
Torque spec for 300 In-line six manifolds? Oldschool1962 Ford Inline Six, 200, 250, 4.9L / 300 9 06-17-2015 11:13 AM
EGR Tube & Manifold Adapter: 1984(ish) 4.9L 300 F-150 4x4 akf150-300 Ford Inline Six, 200, 250, 4.9L / 300 5 05-18-2014 05:03 PM
4.9L ported vaccume not working F100XL300I6 New Member Introductions 3 04-26-2014 07:53 AM
Exhaust info Needed F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 19 04-17-2014 12:49 PM
Replacing the rear exhaust manifold on my 4.9L I6 wildlife agent Ford Inline Six, 200, 250, 4.9L / 300 5 03-24-2008 02:54 PM
Tags
1979, 300, 3006, 4wd, 6cly, 6cyl, 79, f100, f150, ford, inline, manifolds, specs, timimg, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
