99 Expy "clunk" on acceleration
99 Expy EB
5.4L AWD<O</O
252,000 mi
Have to make a 600+ mi trip this weekend and noticed the following:
<O</OUnder a load, there seems to be a drivetrain related “clunk” coming from middle-front end of underside of vehicle. Only happens when accelerating hard from a stop or jumping on throttle as if passing, does not occur at any other time (not while turning, stopping, etc.). Sound can be avoided altogether if acceleration is easy (as I usually do). From reading posts here it sounds like u-joints (?), but welcome any other ideas or T/S suggestions. Truck is in great shape otherwise.
Question: is this a “critical” fix before upcoming trip – or if by accelerating slowly and avoiding the "clunk" can I put off further diagnosis/repair until I return? Definitely don’t want to wind up stranded on side of the road, but also really don’t have a lot of time to address it this week so I'd have to have a pro look at it ASAP (big $$$!). If you were me – what would YOU do?
Appreciate any/all input - thanks.
5.4L AWD<O</O
252,000 mi
Here's a pretty decent write-up with pictures of a double cardan joint rebuild.
http://www.mallcrawlin.com/forum/showthread.php?t=7478
To be a bit more specific. The front u-joint of the rear drive shaft is actually a double cardan u-joint. This cardan joint is really a glorified double u-joint assembly. In between the two u-joints is a spring mechanism to keep a constant pressure on the 2 u-joints to effectively keep them centered to each other. Sometimes this spring loses grease and will cause a clunking on acceleration. If your upcoming road trip is a long one, or if you're pulling a trailer, or going into a mountainous area, or basically if you're going to be loading down the drive shaft more than normal, I would have it inspected before you go. Maybe it is something as simple as sticking a grease gun on the u-joints and giving them a bit of grease to tie you over until you're back.
One last question - I didn't notice them on the photos of the rebuild (maybe missed them?) - but is there normally a grease fitting on the double cardan joint - or would just shooting some grease into the spring mechanism area work as a short-term precaution?
Whoops - went back again and clearly see at least one fitting in a photo - just not sure if that's accessible without disassembling the joint. Can I get to that while everything's still in place?
Sometimes you can, but it depends on the size of your grease gun head. They do make slim heads for grease guns just for the purpose of greasing u-joints. But the way I've always done it, was to detach the drive shaft from the rear flange and bend it over enough to gain access to the grease fittings.
Unfortunately there is no way to grease the centering spring assembly without disassembly.
redman84
17
05-29-2013 12:38 PM
hughjazz
2004 - 2008 F150
06-25-2012 11:42 AM
