brake lights not working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-10-2009, 11:46 AM
willhf1011 willhf1011 is offline
willhf1011 is starting off with a positive reputation.
The brake lights on our tow rig are not working. Its a 2002 F-450. The lights don't work on the truck or at the trailer so that tells me the problem is in the truck. Both rear turn signals work so the bulbs are good. I checked both fuses on the fue panel slotted for brake lights (18 and 34 i think) and both fuses are good and there is current to them. The brake switch by the pedal is good because the electric brake box for the trailer reads when i depress the pedal. At this point i'm stumped. I'm hoping there is a brake light relay somewhere that could have gone bad or more fuses than just the two on the panel beneath the column. I would think that a wire was bad going back but i thought current for the brake lights ran through the same wires as the turn signals and operates the same bulb. Anyone have any ideas?
Old 08-10-2009, 12:26 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I think you'll find another fuse/relay box under the hood. Somewhere on the driver side, fender well.
Brake lights and turn signals are all the same wires and bulbs, as you said, so I would look for that underhood box.
I would have guessed brake pedal switch, but you seem to have eliminated that already.
Old 08-10-2009, 03:31 PM
i found a small relay box with 3 relays in it but nothing beyond that under the hood, maybe i'm not seeing it. i would have thought that the brake lights would have a relay but there isn't one for them under the dash. If the electric brakes on the trailer work then the brake pedal switch has to be good right?
Old 08-10-2009, 03:40 PM
bpounds's Avatar
2 bit Californian
Quote:
That's the box I spoke of. Did you try swapping the relays around, one for another?
If the switch is a single pole switch, then yes. Sorry, I don't have that year truck so I just don't know.
Old 08-10-2009, 04:06 PM
bpounds's Avatar
2 bit Californian
I suggest you take another look at that brake pedal switch. I think you will find it is a multi-pole switch and the PCM is involved. I'm looking at an '05 schematic, so no guarantees. But I do not think you can assume that switch is good just because your trailer brakes work.
Old 08-10-2009, 04:21 PM
bpounds's Avatar
2 bit Californian
If it's not a relay, and it's not the brake pedal switch, then it may be your multi-funtion switch (turn signal lever).
Old 08-10-2009, 04:31 PM
do you by any chance have a diagram or specs on what the purpose of each wire on the brake pedal switch are? you are right in that it is a multi-pole switch so i'm going to unplug it and try to bypass the switch, just need to know what wires are which
Old 08-10-2009, 04:53 PM
bpounds's Avatar
2 bit Californian
Okay, remember, this is an '05 schematic. They could have done anything with wire colors.
The hot wire will be LT GRN/RED (means light green with a red stripe). The output wire will be LT GRN. This LT GRN wire should be hot when the pedal is pushed. The LT GRN wire goes up to your multi-function switch, through normally closed contacts, and comes out as ORG/LT BLU to the right side stop light, and LT GRN/ORG to the left side stop light.
By the way, does your high mounted stop light work (on the back of the cab)? This is important, so make sure it has a good bulb and see if it works. Because that is the same wire from the brake switch, but does NOT go through the multi-function switch. So, if the HMSL works, but the rear brake lights don't, that is a strong indication that the multi-function switch is bad.
If neither HMSL or rear lights work, then it's more likely the brake pedal switch. Also, the LT GRN/RED wire should be hot at all times, even with the ignition key off.
Old 08-03-2014, 02:14 PM
rich1zoom rich1zoom is offline
rich1zoom is starting off with a positive reputation.
No brake lights. Problem Solved....2006 F250 Super Duty. My symptoms started when my truck was fairly new. I had an intermittent warning, TBC FAULT. After 115,000 miles I noticed that sometimes it was hard to get the shifter out of Park once in a while. Then the TBC Fault warning came on almost every time I hit the brakes. Somebody told me I didn't have brake lights including the third light. My flashers and turn signals worked correctly. I saw a goofy guy on You tube playing with his brake light switch located just above the brake pedal. Like him, when I physically turned the switch my brake lights came on. To remove the switch you remove a green safety cover from a clip, remove the clip, slide switch and pedal arm off and disconnect the harness. The only tool used was a small flat screwdriver. My part #F87Z-13480-AA cost just under $30 at the dealership. Inside the switch are three contacts, one must be for the brake lights, one must be for the shifter release.
Old 08-05-2014, 07:48 PM
Will104 Will104 is offline
Will104 is starting off with a positive reputation.
Hey i just had the same problem with my 99 turn but no brake lights and after tracing and testing every wire from the pedal up it ended up being the gem module and a friend had the same problem with his 2011 and it was the module as well and it cost him 800 from the dealer and i got mine from the bone yard for 100, i hope this helps if you know someone with an 02 or an 03 you can try their module. i hope this helps you troubleshoot the problem
Old 08-05-2014, 09:10 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The GEM module has absolutely nothing to do with the brake lights on anything up to and including an 08 (haven't checked the 09-on).
Old 08-05-2014, 10:16 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Try switching the hazard lights on and off a few times and see if the brake lights come back.
Turn Signal/Brake Light Problem rworld Excursion - King of SUVs 12 12-28-2016 11:42 PM
Electrical issue with brake lights waverous 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-10-2016 11:10 AM
No brake lights, hazard or turn signals in the back of truck... CA-Cowboy50 1999 to 2016 Super Duty 3 05-13-2015 10:59 PM
04 ford E250 fuse issues....HELP aronashley 1968-2013 Full Size Vans 3 07-07-2014 08:19 AM
Brake light problem Evel K 1961 - 1966 F-100 & Larger F-Series Trucks 7 06-26-2014 09:34 AM
Tags
2000, brake, brakes, f250, f450, ford, good, light, lights, multifunction, switch, trailer, truck, turn, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
