Why in the world is there no....
IIRC you can bolt a 4R100 pan on to the E4OD, the 4R pan has a drain plug. It's not too bad to deal with though- just unbolt the return line from the trans (rear most line IIRC) and attach a piece of clear hose to it. Start the truck and let it run until you see bubbles in the clear line. Shut down, pull pan... should only be a little left in the pan.
thats what i did. advance auto has drain plugs with nylon sealing washers. used one on 2 trucks with no worries. i used to hate tranny services
on
1 Post
After you run the transmission per Chase's suggestion, you can use compressed air to get more of the fluid out.
Roll the torque converter to find the plug and then pull the plug. Send air back the return line to the cooler and it'll blow all of the oil out of the cooler and torque converter.
Then send the air into the return port on the transmission and it'll blow the fluid out of the passages and into the pan.
on
1 Post
My '97 f350 4x4 doesn't have a drain plug in the pan. I've seen pan plug kits, some weld in, some not. I've even heard of just using a nut welded onto the pan with a bolt threaded into the nut. I might try the "drilling the hole" method and then weld a nut on and make my own drain plug. Not much use in having all these tools if I don't use them.
The stock 4wd pan does have a drain plug. It also hold a bit more fluid. If you put a 4wd pan on you need the 4wd filter to go with it. Cheap and easy mod.
