Door lock acuators
Excursion Door Lock Actuator
6L3Z25218A42AA .. Right Front & Right Rear Door Lock Actuator / (6L3Z25218A42AA replaced F81Z25218A42AA)
MSRP each: $56.18 // FTE sponsor Y2KFORDPARTS.COM price each: $40.45.
6L3Z25218A43AA .. Left Front, Left Rear & Tailgate Door Lock Actuator / (6L3Z25218A43AA replaced F81Z25218A43AA).
MSRP each: $56.18 // Y2KFORDPARTS.COM price each: $40.45.
Y2K aka PARTSGUYED.COM = MILLENNIUM FORD in Seattle WA.
Last edited by Stewart_H; 05-05-2019 at 04:27 PM. Reason: corrected number from 3 to 2 per ND
Well welcome to the forum. When you get a chance, click on the Roadside help network link and go to mods and maintenance and read all you want. There are tons of things there to help you get more use and enjoyment out of your EX.
Here you go, a couple of pieces of aluminum foil and a few hours of your time, if you take your time, and you will be all set.
https://www.ford-trucks.com/forums/4...cks-fixed.html
If you can't fix it for some reason.We have them in stock.Here's a link to that section on our site.
If you have any questions,I'd be glad to answer them for you.
Ford Truck Door Lock Actuator
Fix
https://www.ford-trucks.com/forums/44...cks-fixed.html
Check this out. I haven't tried it yet but it makes sence.
lock actuator
Hello, Search ebay for "door lock actuators" there are many listed thy are aftermarket ones that stereo places use when you purchase alarms and stuff.
i did this to mine several years ago and the still work great and the best thing is they are only $3 to $5 dollars.
You leave your old actuator in and hooked up as factory you can run the new ones inline i only drilled one hole to mount the new actuator I found out which orginal wire is for up and which is for down and spliced the new one into those wires then hooked up the rod with the coupling provided. So when you go to unlock or lock your are still using the orginal with the help of the new one. I have done this to about 10 or more doors and they work like new and it is CHEAP compared to buying factory. it is had to explain how exactly to do it but if you take a little time on the first one you will see how easy it is. You can get all four for less than 420 bucks depending on shipping plus a little time.
Hope this helps
Good luck AL
Hope this helps
Good luck AL
gts2
05-17-2017 10:37 AM
inabind15
01-08-2016 09:34 AM
akfcc350
08-25-2005 12:29 PM
