Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-18-2002, 05:18 PM
LouV14 LouV14 is offline
LouV14 is starting off with a positive reputation.
Post Pine Tree Sap Removal??
Looking for product info or tips to remove pine tree sap from my F250. Any products or ideas are welcome.
Thanx
  #2 (permalink)
Old 04-18-2002, 11:05 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
If memory serves me well, I once had luck with WD-40.
Brian A
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 04-18-2002, 11:34 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold CobraXP is a splendid one to behold
Use some Greased Lightning in with your wash soap and water. It is strong enough to get it off. Or get a spray bottle of it - spray the areas and wash with soap and water. I spray it on, then wash. Comes right off...
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #4 (permalink)
Old 04-19-2002, 02:21 PM
brents's Avatar
brents brents is offline
brents is gaining momentum as a positive member of FTE.
Meguire's quick detailer worked for me,
-Brents
  #5 (permalink)
Old 04-20-2002, 09:15 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE. MustangGT221 has a good reputation on FTE.
I don't know if the grease lightning is a good idea, it might strip the wax off. I like to use lifter one's tar and sap remover, works well and has a lemon scent to boot.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
__________________
Justin-FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
87-96 Forum
  #6 (permalink)
Old 04-22-2002, 02:31 PM
Thanx everyone. I'll give the ideas a try. I'll have to research product availability.
LouV14
  #7 (permalink)
Old 01-05-2003, 02:46 AM
brt brt is offline
brt is starting off with a positive reputation.
The cheapest, best product is regular isopropyl alcohol (rubbing alcohol). You can buy it in any market or drug store for about 75 cents a bottle. You'll have to rewax the spot after using any cleaner. I've used it for all my cars with no problems and it is cheap.
  #8 (permalink)
Old 01-05-2003, 10:17 AM
AlM's Avatar
AlM AlM is offline
AlM is starting off with a positive reputation.
yo,
(from a previous post here (page 3):
yo,
we have same problem when the pine sap gobs up on our Black 96 bronco
We prev tried many brands such as mother's... clay bar and meguiar's clay bar and quick detailer, etc. etc and they didn't get the globs off satisfactorily..
A local detailer/truck accessory shop owner clued us in on using plain rubbing alcohol pads (small 1" cotton pad type available @ any drug store) to remove the globs. It hasn't harmed the finish on our 96.
here are 2 references..one by Ford, and the other recommends the alcohol:
http://www.autoint.com/ford_tree_sap_removal__there_are.htm#FORD%20Tree%2 0Sap%20Removal
http://www.goodspeedmotoring.com/?page=drying
others say: "...Denatured alcohol solvent** (not isopropyl or rubbing alcohol). Make sure the surface is cool and keep the exposure area as small as possible as it may damage your paint. Wash off immediately, use a paint cleaner product to remove any residual sap, and coat with your favorite wax..."
good luck
**Standard disclaimer: Test on a small, inconspicuous area before
using. Not responsible for any damages that may occur due to the use of
this product.
__________________
96 Bronco XL, E4OD, 5.0
Bless all who serve!
  #9 (permalink)
Old 01-06-2003, 04:23 AM
Soggydoggie Soggydoggie is offline
Soggydoggie is starting off with a positive reputation.
  #10 (permalink)
Old 01-08-2003, 09:36 PM
biglevi71's Avatar
biglevi71 biglevi71 is offline
biglevi71 is starting off with a positive reputation.
Ah the fameous tree sap problem. I own a tree nursery including Christmas Trees and the sap is a tricky problem. As suggested earlier WD-40 is one of the cheapest ways to get the stuff off, but shop soap will also work as well. Shop soap will work better for clothes or seats, as the WD-40 will take it off of skin and paint. Also Goo B Gone has taken it off of the top of my truck after a Christmas Tree season has coated the paint. Good luck, it can be a sticky mess, but those things should work, Levi
02 F150 4x4 5.4 V8, auto, 3.55 limited slip, sport, 17" wheels, cat back duals with NO MUFFLER...
__________________
  #11 (permalink)
Old 01-27-2003, 12:15 PM
mantta's Avatar
mantta mantta is offline
mantta is starting off with a positive reputation.
I bought an old Dodge Dart many years ago that had sat under a pine tree for a long time and I used kerosine, it worked really well.
__________________
ENCS(SS), (SW), USN RET (E-8)
Keweenaw Bay, MI
U.S. Navy (Submarine Service) 60-80
1989 F-150 XLT, 5.0, AOD
1999 Lincoln Town Car Sig Series
1930 Model "A" Coupe
  #12 (permalink)
Old 02-06-2003, 04:04 AM
PW01 PW01 is offline
PW01 is starting off with a positive reputation.
GOO-GONE will take it off, and not damage your paint! it will, however, remove wax. so re-wax after sap removal.
  #13 (permalink)
Old 02-07-2003, 03:45 AM
wgm114 wgm114 is offline
wgm114 is starting off with a positive reputation.
wd-40 or bug/ tar remover
  #14 (permalink)
Old 02-23-2003, 07:06 PM
AlM's Avatar
AlM AlM is offline
Ford's Solution:
http://www.autoint.com/ford_tree_sap..._there_are.htm
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
