You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Here is a quick easy mod for your truck; I took the yellow bulb assy. from the top headlight compartment and drilled a hole next to the other yellow bulb in the blinker assy. There is sort of a tab inside the yellow reflector, I just drilled it out. I picked up a set of h-13 hid lights and they fit o.k. in the top headlight spot, I just put a little silcone to hold them in place and seal it. Hooked it up to one of the upfitter switches and it works and looks great. You can get a set of hid lights here from one of our sponsors for less than $100.00 ask for the 55 watt ballasts they are a little brighter than the standard 35 watt ones. It makes a big difference at night for visibility, well worth the few dollars for the lights. The lights are a little more concentrated in the smaller headlight spot, but it kind of works better that way, and they have good alignment on the ground. it looks cool as well.
__________________
2008 ford f-250 cc 5.4 super duty , raider hi rise camper top with thule ladder racks, front winch bumper top gun, rear bumper top gun,12,000 lb. winch, 98 gal. aux tank, on board 12 volt puma air compressor w/10gal tank and 50' auto hose reel,1000 amp 2nd battery,1,000,2,500,6,000 watt power inverters, 9" hid lights, running boards, air horns by hadley, xm radio, fac. 6 cd nav. center, air bags, cb,2-4'12volt flourescent lights in back.
I have tried to post pics a bunch of times and it won't work so I gave up. I would not say this thread is worthless, I am just explaining a good idea, it's not that hard to follow. Thanks for your positive feedback though.
__________________
hmm can't find the "this thread is worthless without pics" smiley....
Where is that ******** smilie face?
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
