Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Lowering Kits
Overview of popular modifications to customize your truck
Aim/DJM lowering kit thread
#76
Williamwilliam,
The photos will be great. What year spindle do you have? Photos of the tie rod relocator from the front and back would be great. I purchased mine back in June and everything is good except that relocator. I purchased the same set as "Filthy". His relocator looks a little different. The tab on it is curved and mine is straight. Yours in the photos look like mine.
Thanks again!!
Thanks again!!
#77
I will check into the poly radius arm bushings. Is there a preferred placeto order them from?
I ordered the beams from airbag it/AIM/ truckin/chassis tech. (Whatever they want to be called this week) I ordered them un powder coated, as I was going to have a friend powder coat them in a different color for me. But, I am so ready to get this truck dropped, I think I'm going to start the install and forget the powder coay, so I can proceed with all of the paint/body and interior and get it done before the show season/spring time/cruising weather.
LMC Truck Parts - Page 103
#78
#80
Williamwilliam,
Thanks again!!
Thanks again!!
JohnDavid,
I just re-read what you posted, and thought I'd chime in. The kit, that I ordered were the lowering beams for drum brakes. (There isn't any difference in the kits, other than the tie rod relocator) You had said, that your set up, had been changed over to 74 style disk brakes, and I would assume, thats why my tie rod relocators look different.
I was also wondering, if you had gotten your situation figured out yet?
I keep trying to start on my install, but life keeps gettin in the way. I really hope to have this done, by the end of next week. Will definately post up pics.
#82
My truck is a '67 and now has '76 spindles with disk brakes. That must be the difference with that tie rod relocator. My tab just doesn't have anything to bolt to like Williamwilliam's photos. Won't be able to look at it this weekend. Like you said, life keeps getting in the way. Lets compare notes!!!
#83
William,
One more question in regards to the rear hanger/shackle setup.
I have recieved the kit, and am looking at the install instructons. I notice, that on the written instructions, it notes that the shackle kit will lower the truck approximately 2" inches. It does in fact, look as the rear of your truck is lowered a touch more than 2" (Looks more like 4-4 1/2) Is there anything else, that you did in regards to the rear set up, differently, other than remove the bottom "helper" spring?
#85
William,
#86
#87
#88
Johndavid,
I took a pic of my AIM tie rod relocators. These are the "disk brake" version. Since, I have now purchased both sets of relocators, and King Pins for both drum and disk brakes, I will have one version up for sale, as soon as I finish my install. Should have everythign wrapped up tonight.
#89
Just thought, I'd fill everyone in on my current nightmare. Airbag it has now shipped me the wrong parts two times. I've got everything on the truck broken down, and am almost finished with the front end. They sent me the tie rod relocators for drum brakes originally, and now that I'm getting into the install, When I went to install the shackle kits they are the wrong size. Looks like they sent me the shckle/hanger kit for an f200.
There wasnt a packing list of any kind, and none of the parts were marked/noted. the difference int he shackles are just the width. (a difference of 1 1/4 inch)
Either way, this entire experience has been horrible up to this point.
#90
