2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Towing Capacity of 4 x 4 EL?
Old 08-09-2009, 09:29 PM
Scott_Free's Avatar
Scott_Free
Scott_Free is offline
My 2007 EL did not come with the towing pkg, however in looking over the specs I see the 4 x 4 EL comes with the 3.73 ratio rear end, the rear air adds the oversize 23+ quart radiator and it has a factory tranmsission cooler.
Obviously the welded hitches are the same. I have added the 7 pin plug.
What is the difference now between mine and the towing option? could the tranmission cooler be larger? Is the towing radiator larger than 23 quarts?
I will be towing 7,000# max but it will be in Mountains.
What suggestions would you have for me? Is there a drain plug in the 6 speed that can be replaced with a tranmission temp sensor?
Should I add an aftermarket H/D tranny cooler with a Fan? I see they are fairly inexpensive.
Many Thanks!
Old 08-09-2009, 09:50 PM
hookd's Avatar
hookd
hookd is offline
first you might want to start with the tranny cooler I know the HD tow package has a larger one also make sure you have a good brake controller we learned the hard way stopping everything is more important than getting it all going and finally if you are still worried look at chuck s posting for the OBD II gauge that plugs right in and can tell you tranny temps along with all sorts of good info and you should be set.
Old 08-10-2009, 09:00 AM
Scott_Free's Avatar
Scott_Free
Suggestions for Transmission coolers?
What are some suggestions for aftermarket Transmissions Coolers for 2007 Expedtions?
Is there one with a fan and a temp gauge built in that someone has had good results with?
Thanks!
Scott
Old 08-10-2009, 07:00 PM
chuck s's Avatar
chuck s
chuck s is offline
As near as I can tell the HD radiator is only 0.6 quarts bigger.
Engine coolant (Base
radiator with aux rear
heat)
23.2 quarts
(22.0L)
Engine coolant
(Heavy-duty trailer tow
heat)
23.8 quarts
(22.5L
The HD transmission radiator may just "drop in."
But you may want to just monitor the trans oil and engine coolant temperatures with an ODB2 gage. Just plugs in under the dashboard.
-- Chuck
v101998
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
24
11-11-2015 07:08 PM
theoldwizard
09-14-2015 07:15 AM
vpoolman
04-22-2015 09:03 PM
tennhillbilly
15
03-12-2014 04:00 PM
99expyTN
1997-2006 Expedition & Navigator
09-20-2013 04:00 PM
Quick Reply: Towing Capacity of 4 x 4 EL?
