Battery Dilemma
Battery Dilemma
So, I got in my truck this morning and the familiar slow crank and then the tick. Ya, the battery is dead. The problem is, the parts department is closed today and considering the factory battery has been in my '05 since it left the factory, I want another Ford battery. I need my truck for work but won't be able to get a battery before I start work. I've never had another battery last more than 2 years in this Arizona heat. Anyone had luck with an aftermarket battery that you can get at an auto store so I can go to work tomorrow and not waste money on a crappy battery?
Battery problems
I also live in the Valley area but find if a battery lasts more then 3 years I'm on borrowed time.I've had good luck with Autozone yellow top batteries. Many opinions as which battery is best but with the heat check it and try to replace it before the warrenty is up.
Good luck.
Good luck.
While im DEFINATELY NOT a fan of Autozone,they have 2 products that I will buy from them...batteries,and oil.
Ive had many cars with AZ Batteries in them,and only one failure in about 12 years.They replaced it no questions asked....
Cant fault you for wanting Motocraft,but AZ will be fine.
Hey everyone, check out this site.
http://batteryfaq.com/
You will see that Johnson Controls makes the batteries for: Sears Diehard, Autozone Duralast, Wallmarts Everstart, MOTOCRAFT and Optima.
I don't know who makes Costcos, Kirkland batteries, but I've had good luck with them.
Back in the '70's, there were only three manufactures of all automotive batterys in the U.S. ESB, Exide and Guild (sp?)
