F-150 302 Fuel Mileage
I bought a 1990 -150 with an injected 302 in September. Its a flat bed with an Approx 5" body lift on the cab. 31.5X10.5x15 tires. When I got it there was no question it ran bad and I got about 10 MPG. After a few months I tore into it and found why it was missing, Burned exhaust valve which inturn cracked the head. 2 new heads later, I still get 10 MPG runnin around, 12 highway. Whats normal for a 302 like this? Seems low to me. What work can a guy do to a 302 to improve mileage?
on
First off how are you determining milage? It should do 15 around town and even better on the hwy.
It's EFI right? What tranny?
Is the O2 sensor present and electrically connected?
Dual or single tank?
What is fuel pressure?
Any signs of fuel in the vacuum line from the FPR?
Any codes present?
Any codes present?
The 5" body lift is going to kill your mpgs....
those tires aren't that much bigger than stock though so it probably wouldn't be off by too much i would assume....
Mine is lucky to get 14 on the highway, but it runs like cow manure.
what is the flatbed made of? wood? diamond plate? more weight=less mpgs. I would still think you'd be getting slightly better than that tho..
Don't know your trans or if 4x2 or 4x4, but read it and weep:
http://www.fueleconomy.gov/feg/sbs.htm
1990 302, 3 speed auto, 4x4 EPA rates 11/12.
4 speed auto: 12/16
5 speed manual 11/15
4x2:
3 speed auto: 12/14
4 speed auto: 12/17
5 speed manual: 13/17
YMMV
4 speed auto: 12/16
4x2:
3 speed auto: 12/14
4 speed auto: 12/17
YMMV
on
Any exhaust leak upstream of the O2 will affect milage so check that out, inspect the tube that connects the heads across the back of the motor this rusts out or cracks and will sound like a manifold leak. You should also check the other things mentioned as they could all contribute to the problem.
kermmydog
05-08-2017 04:27 PM
redbayredneck
11-06-2016 11:37 AM
