Cruise Control Problem - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 08-09-2009, 05:19 AM
wxscoe's Avatar
wxscoe wxscoe is offline
wxscoe is starting off with a positive reputation.
Have an 05 Expy w/74,000 miles. We just made a trip have way across country and back, and the cruise control starting shutting it self off. At first it was after we used it for a while, then it started shutting off right after we set it. My father-in-law thinks it's just a vacuum leak that can be fixed pretty inexpensive. Has anyone else had this same problem? If so, what was the cause?
Old 08-09-2009, 07:18 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The 05 Expy doesn't use vacuum for the cruise (it's all electronic and is controlled by the PCM) so Dad's idea won't pan out.
Have the system scanned with a scan tool that is capable of reading "manufacturer-specific" codes as any speed control fault will be logged by the PCM, same as an emissions fault but without a visual fault indicator.
Common failures include the deactivator switch, the BPP switch, and the clockspring.
Old 08-09-2009, 08:24 AM
wxscoe's Avatar
Thanks for the info, will have it checked out.
Old 08-13-2009, 03:35 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
If the airbag light comes on too.It's more than likely the clockspring.
Old 08-14-2009, 04:30 AM
wxscoe's Avatar
The airbag light doesn't come on.
Old 08-14-2009, 01:40 PM
bnovak bnovak is offline
bnovak is starting off with a positive reputation.
is it turning the cruise off entirely, or just disengaging it?
if it's dis-engaging, as Project said, it's going to most likely point to one of the switches.
Old 08-14-2009, 07:04 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
Those units had a Ford Recall I think (check with your dealer). Just ask your dealer if the cruise control recall work was done on your SUV.
Sounds as though you have a switch problem and I don't know if the switch is replaced under the recall or not. Seems as though a fuse is installed in the circuit on the recall.
Old 08-14-2009, 09:10 PM
No, the speed control recall did not affect the 05s.
Old 08-14-2009, 09:51 PM
wxscoe's Avatar
We already checked the recall, it didn't affect the '05's as project said. It's turning it off completely.
Old 08-14-2009, 11:00 PM
I don't know how to check the clockspring, but to test if you are losing power to the system, check the yellow /lt blue striped wire coming off fuse 5 in the distribution block. It goes through the horn relay and comes out dark blue then goes into the clockspring.
Might be worth probing it and giving the connections a shake. Or, check fuse 5 (20a) who knows maybe it's loose, or the horn relay is starting to crap out.
Since it's turning off all togethor, I think you can rule out the brake pedal and speed sense switches, but could be wrong.
Old 08-15-2009, 04:02 AM
wxscoe's Avatar
Thanks for all the suggestions. Will look into them when I get some free time.
2003 F250 7.3L Auto Cruise Control shutdown RPMS up F250truckers 1999 - 2003 7.3L Power Stroke Diesel 2 12-09-2015 02:19 PM
Intermittent cruise control problem on 2008 F-250 Tawn 1999 to 2016 Super Duty 1 07-28-2015 09:36 PM
3K miles from home/strange issue with truck Sous 1999 - 2003 7.3L Power Stroke Diesel 18 07-24-2015 10:56 PM
1989 cruise control would not shut off! HELP! Jeff W. 1987 - 1996 F150 & Larger F-Series Trucks 10 01-27-2015 11:07 AM
Cruise control wont disengage RAMBOv10 1999 to 2016 Super Duty 12 03-12-2009 08:27 AM
Tags
05, 2000, 2004, control, cruise, f150, failures, ford, locations, navigator, problem, recall, relay, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
